How to take off integra rear bumper!!!
Hey guys,
I need to take off the rear bumper off my 95 integra i searched everywhere i cant find anything on it. So please someone tell me where are more bolts to remove the rear bumper or any site that shows instructions.
These are the ones i know about
2 on each side.
2 on the bottom
I see the clips but i dont know how to open them.
thanks in advance
2 on each side.
2 on the bottom
thanks in advance
you have to take the metal piece above the bumper off to get to the clips.
1. take the tail lights out.
2. from the inside of the trunk remove all the 10mm nuts (i think 8 of them) that hold the metal piece thats above the bumper and below tail lights. once that is off the clips should be easy to take out.
Good luck.
I hope my description helps.
Good luck.
http://www.team-integra.net/se...D=452
It should be a requirement for Integra owners to join team-integra.. so if you aren't already, join!
Here's how you do it:
1. Remove inside rear interior panel. (should be like 4-5 plastic screw holders)
2. Loosen Rear interior quarter panels (Several 10mm bolts)
3. detach the platic wheel well coverings from the bumper, if necessary, and remove the two screws which hold the front part of the bumper onto the body (One screw per side)
4. Remove the four 8mm nuts from inside the rear hatch area...two were situated behind the rear center panel and one is situated behind each rear quarter panel
5. Pull off bumper....you're done!
EvenStar
Dec 28, 2006 06:34 PM
SupraRXZ
14
Nov 29, 2006 10:30 AM
