Who's run DOHC ZC (1st gen Teg) pistons in their D16A6?
Old Mar 18, 2004 | 01:33 PM
Steve91's Avatar
Default Who's run DOHC ZC (1st gen Teg) pistons in their D16A6?
Did you have to do and clearancing on the pistons for the valves to clear? Were you running a stock cam?
I'm looking to build a 14:1 compression motor and ZC pistons make it pretty easy to do.
Old Mar 18, 2004 | 01:42 PM
LudeEFv2.4's Avatar
My old title sucked.
Default Re: Who's run DOHC ZC (1st gen Teg) pistons in their D16A6? (Steve91)
a friend of mine did it 13.5:1
it lasted like 6 weeks
Old Mar 18, 2004 | 03:23 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: Who's run DOHC ZC (LudeEFv2.0)
i am using P29 with a head milled one thousanth, OEM gasket with a Rocket cam, we clayed it and there was no clearance issues.
How are you planning to get 14:1 CR? welding the head?
stan
Old Mar 18, 2004 | 03:41 PM
Steve91's Avatar
Default Re: Who's run DOHC ZC (Stan D)
The head is welded and I will run a cometic .030" head gasket. On a 75.5mm bore, that will give me close to 14:1
oldskool88291
11
Dec 31, 2007 06:29 AM
hatchinprogress
Nov 23, 2005 11:27 AM
1point7db2
Oct 4, 2005 02:52 PM
clsmooth
Dec 3, 2002 04:53 PM
