ls/vtec people!!!!
Old Mar 18, 2004 | 12:55 PM
SIanara's Avatar
Default ls/vtec people!!!!
i have a friend doing this build and he needs to know everything to do with and to the engine to complete it. also so it doesnt BLOW up when he drives it. so if any one can run off like a "check-list" that'd be great.
Old Mar 18, 2004 | 01:00 PM
t . b o z's Avatar
there is a "search function" on this forum.
Old Mar 18, 2004 | 01:29 PM
mr.beeks's Avatar
Default Re: (DA-teggy)
search should have been the first thing on your list..
Old Mar 21, 2004 | 07:36 AM
SIanara's Avatar
i've found some topics on ls/ vtec but nothing that i can use. so i'm asking you guys.
Old Mar 21, 2004 | 07:59 AM
Kendall's Avatar
Be sure you also search for LS/VTEC, LSVTEC, LS VTEC, and any other methods of putting it.
Personally I would stay away from the setup unless I had enough money to fully build it. One of the biggest issues that's often overlooked is the balance of the crank, be sure that a reputable machine shop balances it. I would go with forged internals even if for no other reason that the increased heat dissipation that they offer over cast internals. Sleeving it isn't necessary, but isn't a bad idea. If you're unfamiliar with the setup, make sure you get a kit like the Golden Eagle kit to make things easier. There are lots of other "dos" and "don'ts" of LS/VTEC setups. Search and find out.
Old Mar 21, 2004 | 08:01 AM
DOHChi's Avatar
Default Re: (vteGraGSR)
You loser cant even use search properly
here is way to maintain your ls/vtec https://honda-tech.com/zerothread?id=501372
here is how to build one http://www.c-speedracing.com/h...c.php
Old Mar 25, 2004 | 02:39 PM
B18civic5g's Avatar
Default Re: (DOHChi)
thanks for the web site helped out a lot
Old Mar 25, 2004 | 03:29 PM
DOHChi's Avatar
Default Re: (B16civic4g)
haha no problem, hope ur cars fine
Si2See
Apr 6, 2008 08:31 PM
95_red_dc
May 24, 2006 01:02 PM
aaroboost
Jan 2, 2006 10:26 AM
redsivik
Mar 1, 2004 07:21 AM
jspek29
Feb 9, 2003 09:55 AM
