tire grinding
Old Mar 18, 2004 | 11:14 AM
theharlequin's Avatar
Default tire grinding
so this morning going downhill, my car slid on slush and hit the guard-rail on the passenger side. the bumber is cracked and the headlight is broken. all cosmetic and nothing im too worried about. but...
the wheel on the passenger side is dented in toward the car. and when i make left turns, there is a grinding sound. is there any suggestions ti what the wheel damage is and how much it would be around?
also the steering-wheel is off centered (the 'H' is slanted). so could this be an allignment problem?
Old Mar 18, 2004 | 12:08 PM
Filthy Focker!'s Avatar
Default Re: tire grinding (theharlequin)
You have possibly damaged a steering component. Take it to a shop. Can't really estimate the damage, i can't see the car...
fs
Old Mar 18, 2004 | 12:24 PM
crx_88_si's Avatar
Get a friend to bring his car over (Same car) and compare sus components.
Old Mar 18, 2004 | 12:28 PM
hondaaaaah's Avatar
maybe get a wheel alignment done. chances are you fucked it up when you hit the guard rail.
Old Mar 18, 2004 | 12:31 PM
hondaaaaah's Avatar
Default Re: tire grinding (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">Get a friend to bring his car over (Same car) and compare sus components.</TD></TR></TABLE>
LOL DUDE, you would have to have waaaaaaay too much time on your hands to be doing stuff like that!
Old Mar 18, 2004 | 12:36 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by theharlequin &raquo;</TD></TR><TR><TD CLASS="quote">the wheel on the passenger side is dented in toward the car. and when i make left turns, there is a grinding sound. is there any suggestions ti what the wheel damage is and how much it would be around?
also the steering-wheel is off centered (the 'H' is slanted). so could this be an allignment problem?</TD></TR></TABLE>
Yes, or worse.
You probably bent or broke suspension and/or steering components.
The grinding sound is probably the inside edge of the tire rubbing against the fender liner.
hcaulfield57
Suspension & Brakes
16
Aug 27, 2017 03:09 PM
prelude_93vtec
Mar 5, 2008 09:31 AM
hmooblis
Mar 31, 2007 05:05 PM
crxzcracer
Mar 26, 2005 06:08 PM
black sohc civic
10
Jan 24, 2005 09:01 AM
