Help - Rear Lower Strut Bar Installation
Old Mar 18, 2004 | 11:08 AM
shyboy_02's Avatar
Default Help - Rear Lower Strut Bar Installation
Hi everyone,
I've just bought a rear lower strut bar for my 1995 Honda Accord EX 4-Door and need help with the installation. What do I do first and second and where does it go exactly? Please help, I need to install it today. Thanks Alot.
Old Mar 18, 2004 | 11:15 AM
Nick H's Avatar
New User
Default Re: Help - Rear Lower Strut Bar Installation (shyboy_02)
well, it should be designed to connect the bottom of the rear struts together...there should be a bolt running through the lower fork of them...the problem is that these bolts are a bitch not to break...good luck getting them off and not breaking them...
Old Mar 18, 2004 | 03:25 PM
MAFA's Avatar
you a hex key and a wrench set.
Old Mar 19, 2004 | 09:21 PM
shyboy_02's Avatar
Default Re: Help - Rear Lower Strut Bar Installation (MAFA)
Thanks guys, go the job done and clean.
Old Mar 19, 2004 | 11:04 PM
Regulator's Avatar
what brand did you use? post up some pics, i'm not sure if this lower strut bar you're talking about is also a rear lower tie bar
Old Mar 23, 2004 | 12:14 AM
shyboy_02's Avatar
Default Re: Help - Rear Lower Strut Bar Installation (Regulator)
I already got this done. Its a Megan Racing Rear Lower Tie Bar. Thanks for the help guys.
Laters.
Old Mar 23, 2004 | 02:40 PM
Regulator's Avatar
so what did you use to take the bolt off that apparently easy to break?
Old Mar 23, 2004 | 05:08 PM
iam7head's Avatar
did you use longer bolts? well, you should
did you mess up your rear wheels alignment? you might.
MechEng
Dec 24, 2008 10:36 AM
g07ph0
Dec 25, 2005 07:07 PM
JDMCRX
Apr 12, 2004 12:21 PM
yesterdayz
Apr 24, 2003 02:36 PM
hybrid22l
Jun 3, 2001 10:25 AM
