just finished zc awap, but?????
im sure u can find those codes if you look around on the internet.
google is your friend.
but i'd assume those codes are going to have something to do with you flooding the engine with fuel.
gluck
gluck
Go to http://www.thezcr.com you will be able to find much info there.
I have a zc and any probs. I have are quickly solved through this site.
My ZC runs great, Idles smooth and takes off because of thezcr.com Good luck.
http://www.c-speedracing.com/faq/05.php
codes 3 & 5 = map sensor
code 9 = cylinder position sensor (did you run the two wires to the sensor on the exhaust cam of the ZC?)
code 10 = IAT sensor (intake air temperature)
maybe you have some plugs mixed around.
