CRXsi in storage seems out of gas.
Old Mar 18, 2004 | 06:18 AM
davechuck's Avatar
Default CRXsi in storage seems out of gas.
I've got a 88 CRXsi for sale that hasn't been started in a month. The Battery is fine. But it was low on gas before storage and now SEEMS out of gas. (evaporation?)
I poured a gallon in but no dice. The starter just cranks and cranks without firing up the motor. Is there a priming procedure that could help? It's fuel injected of course.
Thanks
Old Mar 18, 2004 | 06:42 AM
Cory man's Avatar
Default Re: CRXsi in storage seems out of gas. (davechuck)
Is the fuel pump turning on? If it is you will hear a slight hum from under the rear storage compartment. If not I'd bet that the main relay is to blame. Make sure you are getting spark as well. BTW if you cant hear the fuel pump try starting the car and while its cracking crack the small bolt on the fuel filter, if no fuel comes out then you know the fuel pump or main relay is to blame. hth
Old Mar 18, 2004 | 07:04 AM
davechuck's Avatar
Default Re: CRXsi in storage seems out of gas. (Cory man)
Thanks. No, I don't hear a thing with the key on, until it's in cranking position. I may try the small fuel filter bolt check. Will fuel spew all over? What kind of pressure is it under, normally?
Old Mar 18, 2004 | 02:40 PM
XrcR6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davechuck &raquo;</TD></TR><TR><TD CLASS="quote">Thanks. No, I don't hear a thing with the key on, until it's in cranking position. I may try the small fuel filter bolt check. Will fuel spew all over? What kind of pressure is it under, normally? </TD></TR></TABLE>
If its at spec. it should be about 35-40psi. You should have a rag wrapped around to catch the spray.
Old Mar 18, 2004 | 04:06 PM
Cory man's Avatar
Default Re: CRXsi in storage seems out of gas. (XrcR6)
Make sure to cover up the bolt when you go to loosen it. If you arent hearing anything when you switch the ign on then i'd be about 100% sure its the main relay.
Old Mar 18, 2004 | 04:10 PM
RCautoworks's Avatar
It was in there for a month ? Are you sure there was nothing else in the tank ? There could be water in the tank.
smileygreasy
15
Apr 19, 2015 07:36 PM
DO-WORK-SON
Apr 7, 2013 07:33 PM
Pena-bb4-620U.M
Oct 28, 2012 07:17 PM
Built4Battle
Jun 7, 2011 11:49 PM
crazygerman
Mar 4, 2006 11:57 AM
