stock 2.2 vtec g/box problems
Old Mar 18, 2004 | 05:20 AM
omega_0000's Avatar
Default stock 2.2 vtec g/box problems
i`m running a stock '95 lude, 5spd manual box, and UKDM (i`m a brit ya see)
it's grown a problem with the box, 1st thru 5th gear is fine. reverse gear would not engage. (this was last tuesday). i looked at it at work, and got it working that night - removed the rearmost cable from g/box, and used a lever to engage gears, reconnected cable and was 95% good - slight roughness coming out of reverse gear (all other gears are fine). it was alright wednesday, but this morning (thursday) i arrived at work, reversed up, tried to stick it in neutral but wouldnt come out. gave stick a wiggle and a few taps with hand, and it gave. it's now back to the way it was wednesday - 95% good, with the slight roughness coming out of reverse.
i admit that i`ve crunched the gears a couple of times (not had clutch fully depressed), but not used excessive force.
could i of streched gear cables, or is it a more serious gearbox problem? new cables are £240 in UK from dealer so it's not really a trial & error job.
any info appreciated.
Lindsay Horton
Mar 23, 2018 07:51 PM
Pdiddy2
Transmission & Drivetrain
May 8, 2017 06:52 PM
Pdiddy2
May 8, 2017 03:19 AM
Black R
Aug 9, 2005 07:27 AM
