B18C5 into a EG Hatch.
lets say i wanted to drop a itr engine into a hatch, rip out some of the interior and toss on some slipstreams for a reliable daily driver. sounds good to me, would move it around somewhere in the 14's from what i've heard.
i've been trying to figure out the total expenses of doing this... i searched and came across this thread: https://honda-tech.com/zerothread?id=540308
now here is where i am lost:
is the swap a direct plug and play like B18C5-EH2 said???
or will i have a wiring nightmare on my hands?
if i get a hatch that didn't have a vtec engine, will i need to add anything?
what mounts will i need in order to drop it into the hatch?
approx. what will it cost to get it all in, said and done?
i tried searching, but came up with TONS of pages and couldn't find my answers.
thanks to anyone who will take the time to give me a serious answer.
B18C5-EH2's engine...
Damn, alot of questions.
Here is someone selling an ITR block for $2200 or best offer here on honda-tech.
https://honda-tech.com/zerothread?id=797403
the swap is as easy as he said... Tom(B18C5-EH2) is pretty in depth with his replies and likely has covered every base(I only skimmed the linked thread)
edit: you need a rear mount from a 94-01 teg or 99-00 Si I belive..(can't remember exactly so do not take this as fact). that should be it for mounts.
OBD2--->OBD1 Jumper.
Get all the mounts and mix/match them until it fits
run 7 (pretty sure) wires if it has no VTEC wiring provisions
Change the fuel pump to an ITR
Buy some better brakes
Jump in and go.
(Simplified, but it goes like that.)
Jump in and go.
let me just say this
if 18c5-eh2 said pretty much anything honda related, i would bet on it.
but to be fair, it is just a b-series into a car that was meant to have a b-series in it anyway..... hope that makes sense
if your worried about wireing up the vtec, just a get a 92 hatch, pre-wired for vtec.
isnt honda grand...
isnt honda grand...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REVHARD_EF »</TD></TR><TR><TD CLASS="quote">OBD2--->OBD1 Jumper.
Jump in and go.
(Simplified, but it goes like that.)</TD></TR></TABLE>
so get something like a skunk2 OBD2 TO OBD1 Conversion Harness for $80?
what models came with the wiring provisions?
get a better fuel pump (how many lph??)
Jump in and go.
heres one https://honda-tech.com/zerothread?id=550976
and another https://honda-tech.com/zerothread?id=131949
FAQ can be very helpful
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SikCivic »</TD></TR><TR><TD CLASS="quote">umm its kinda late so maybe im out of it but
get the obd2 c5 use the obd2 harness and ecu? is it any more simple?</TD></TR></TABLE>
have fun with that on a obd 1 car....
god damnit. i dont get this.
heres what i understand right now, based on this and the other threads by b1c5-eh2
i need: the engine and everything that comes with it
an obd1 -> obd2 conversion harness
a better fuel pump
and wires to wire vtec if its not a 92 or a si or vx
what mounts do i need.
a better fuel pump
man you got this guy confused. its an obd1 car
just get the complete itr swap
get a obd1 p28 ecu and send it to kenji and have him chip the ecu for you. just tell him what motor your going to run and he'll know what to do.
you can wire up the vtec yourself if your car isn't already wired up. do some searching and you'll find out how to wire it up. i'm sure people will also help you on the board and how to wire it up or point you to the right direction on where to find that info.
my friend has an itr swap in his hatch with full interior. 14 flat is what he is running. he is still using his stock dx fuel pump too.
good luck
good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockhatch »</TD></TR><TR><TD CLASS="quote">just get the complete itr swap
good luck</TD></TR></TABLE>
ah. finally a straight answer.
will i need any other wiring harnesses such as an obd conversion or whatever?
and im still stuck on the mounts..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbell »</TD></TR><TR><TD CLASS="quote">
and im still stuck on the mounts.. </TD></TR></TABLE>
if you use the rechipped p28 ecu, you wont need a harness. If you get a usdm b18c5, use the stock wiring harness, it plugs right into the civic shock tower harness. If you get a jdm motor, you'll have to get a 92-95 civic si/ex engine harness, or a 94-01 integra gsr/type r harness. You can use all of the integra upper mounts and lower torque mount brackets, but you have to use the civic lower torque mount unless you want to modify your frame rails. You'll also need the type r/b16/ls throttle cable. If you are getting the motor from a reputable place like http://www.hmotorsonline.com, http://www.importautosalvage.com, or http://www.passwordjdm.com , they should send you just about everything you will need.
yeah...no conversion harness will be needed. just get the obd1 p28 ecu and have it chipped.
if you get the complete swap from hmotorsonline....they will give you the mounts with the swap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by envision2teg »</TD></TR><TR><TD CLASS="quote">OBD-II + OBD I wire harness + OBD I ECU = goodness
its not the motor that is dependant it is the wiring</TD></TR></TABLE>
posts like this are a waste of time. wtf does = goodness mean.
if you are going to take the time to post, at least explain why its "goodness"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockhatch »</TD></TR><TR><TD CLASS="quote">yeah...no conversion harness will be needed. just get the obd1 p28 ecu and have it chipped.
if you get the complete swap from hmotorsonline....they will give you the mounts with the swap. </TD></TR></TABLE>
do you think it'll come with the throttle cable i need?
ok.
so heres what i gotta do
get the complete change over (USDM) from hmotors for $4900
get a new fuel pump for $100
get a p28 ecu $100
get it chipped (how much?)
throttle cable $25
that should be it right?
get a p28 ecu $100
throttle cable $25
Well I hate to advertise something I have for sale here but I think it fits the need.
I have 2 ITR JDM engines ready to go. Dynoed the car a couple weeks ago...well heck heres a scan of the chart.
Pic of the Engine.
The reason why I bring up this swap is its a complete plug and play swap. Yes it is jdm...but you get all my wiring, dont need any of it for my upcoming swap. You get a Kenji chipped ecu as well. I Probably dont even need the intake anymore.
BTW the wiring harness was professionally done by the lead mechanic here at our local Honda Dealership. Hell he pretty much did the entire swap with me pitching in on the all the aspects of the swap.
All the mounts will still be on the engine, the throttle bracket...again made by my guy at Honda. In addition it of course has a fresh Timing belt, water pump, itr shifter, lsd trans, and of course tuned and valve adjusted through...Honda.
$4500.00 plus shipping.
I hope you all see this as more than just a shameless plug...
Pic of the Engine.
Get a hold of kenji on here and have him chip a p28 ecu for u,tell him you want a usdm itr spec.
When you get the motor make sure the wireharness is uncut,if its cut,then just get a usdm gsr or itr harness.
Use the rear bracket from the integra motor and the civic rubber for the back mount.
Use both the integra rubber mounts for both the passenger and driver side upper mounts.
And use the integra lower brackets with the civic rubber mounts for both the mounts down in the fender wells.
Also the stock civic fuel pump will be just fine for the integra motor.
