so which camber kit is really the best?
Old Mar 17, 2004 | 09:39 PM
DarkCyde SI's Avatar
Default so which camber kit is really the best?
i have heard mixed about everything? are there any other choices besides skunk 2, ingalls, or specialty products? here are what i have read in the archives
ingalls: too weak, squeaky
skunk 2: prone to collapsing, weak ball joints
specialty products: squeaky
Oh and while i'm at it i was wondering how many degrees of adjustability i would need. i have a 2000 si and i can't tell how many inches i'm dropped because i have coilovers but i don't want the tucked look. just enough so there is only one finger or tire /fender gap. so how ever much of a drop that is, is what i have. any help. and please don't tell me to search because i did search and found bad stuff about all of them and was just wondering if i had any other choices other than these two
Old Mar 17, 2004 | 09:40 PM
Jawad.'s Avatar
Default Re: so which camber kit is really the best? (DarkCyde SI)
i should have never cheaped out on my camber kit... it does the job... but squeaks like hell.
dropzone
should have gotten the skunk2 unit.. so i can adjust caster too
Old Mar 18, 2004 | 04:21 AM
93CivicSiSOHC's Avatar
Well i have searched for ever and found a lot of people complaining about Skunk2 blts loosening and they are prone to being squeeky.
As far as he cheapo companies making knockoffs...i would recomend staying with the ingalls units...you can't go wrong and they are of very good quality...
i have them installed on my cars and i have a bunch of friends that have the Ingalls and are very happy with them..installation usually takes about an hour..can't go wrong with that.
I have ad no complaints with these...they are great.
Old Mar 18, 2004 | 04:44 AM
monicle's Avatar
My vote is SPC. Ive had them for over 2 years and I dont know what this squeaky issue is youre talking about.
Old Mar 18, 2004 | 04:58 AM
Mike_C's Avatar
Skunk2. Prone to collapse/shifting but as long as you check it now and then and used some loctite you will be fine.
Old Mar 18, 2004 | 05:27 AM
6SPD_EK's Avatar
how much $$$ do you have $850...I should have A-sport front & rear (pictured is for an ITR) for my 2000 hatch by the end of april.
they allow for adj. camber & caster. I plan on autoXing & eventually tracking my hatch & these come highly recommended by A&J racing... I have read too many posts of people having problems (ie hitting shock towers,slipping, braking) with ignalls, skunk2, spc
before you flame me for being a JDM ***** I am not getting this kit just so I can correct negative camber on the street, but to give me negative camber for the track (& maybe autoX) without problems
Old Mar 18, 2004 | 07:39 AM
cre18's Avatar
Default Re: so which camber kit is really the best? (adirondackR)
i'm running skunk2 up front and specialty in the rear on my ek hatch. haven't had any problems so far
Old Mar 18, 2004 | 09:24 AM
silverEH2's Avatar
Default Re: so which camber kit is really the best? (cre18)
i would get ingalls but everyone says you have to bend the upper control arm so it will clear the fender
Old Mar 18, 2004 | 09:29 AM
Default Re: so which camber kit is really the best? (silverEH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverEH2 &raquo;</TD></TR><TR><TD CLASS="quote">i would get ingalls but everyone says you have to bend the upper control arm so it will clear the fender</TD></TR></TABLE>
why would you want to bend that...i have heard to shave a little off of the control arm to get more clearance...
Old Mar 18, 2004 | 09:32 AM
silverEH2's Avatar
Default Re: so which camber kit is really the best? (93CivicSiSOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CivicSiSOHC &raquo;</TD></TR><TR><TD CLASS="quote">
why would you want to bend that...i have heard to shave a little off of the control arm to get more clearance...</TD></TR></TABLE>
but why would you even want to do that?
Old Mar 18, 2004 | 09:36 AM
SD_EM1's Avatar
spc. i have them around the whole car. no problems so far. good stuff
Old Mar 18, 2004 | 09:49 AM
SkRiBLaH's Avatar
Default Re: so which camber kit is really the best? (mr. miyagi)
Omni-power camber kit !!
very high quality... im getting my set soon.. and they are inexpensave!!
Old Mar 18, 2004 | 09:52 AM
BatuKing's Avatar
Default Re: so which camber kit is really the best? (SkRiB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkRiB &raquo;</TD></TR><TR><TD CLASS="quote">Omni-power camber kit !!
and they are inexpensave!!</TD></TR></TABLE>
same as the skunk kit..
Old Mar 18, 2004 | 09:54 AM
MikeNice's Avatar
I haven't heard no problems about Skunk 2.
silverEH2's Avatar
Default Re: so which camber kit is really the best? (MikeNice)
how do the ball joints hold up on the omnis?
Old Mar 18, 2004 | 10:10 AM
drewlee's Avatar
I ran the ingalls and I havent had any problems since I have put them on.
Old Mar 18, 2004 | 12:15 PM
silverEH2's Avatar
Default Re: (drewlee)
Old Mar 18, 2004 | 12:20 PM
B18C5-EH2's Avatar
Former Moderator
Loved
I've had skunk2 for about 3 years now with ZERO problems.
They USED to have weak balljoints, but they have been updated and I installed my updated ones a few months ago even though my originals were just fine.
S.P.C is great as are the Ingalls.
If installed correctly any one of the kits mentioned should be fine. Part of that installation should be using a grease gun to pack the joints on the Ingalls and S.P.C if I recall correctly, which should remedy any squeaking.
Also here's how i'd set your car up since I do alignments daily on these cars:
Front:
Toe - .04 both sides (dead center toe spec)
Camber - -.8 (you're allowed a full -1 if you want to)
Rear:
Toe - .08 (dead center toe spec for rear)
Camber - Anything between -2.0 and -1.0 (you're allowed a full -2.0 in the rear on 1996-up)
GSRswapandslow.
Guest
Posts: n/a
deff go with Omniman's stuff
he worked for skunk2 back in the day...and is not bring out products made from teh same producer, but is selling it for cheaper!
Old Mar 18, 2004 | 12:22 PM
accurate's Avatar
I've only had experience with the skunk2, but like the others said, it's prone to breaking if you don't check on them
Old Mar 18, 2004 | 12:23 PM
dpw41285's Avatar
Default Re: (silverEH2)
hadn't heard any complaints on any of thoose mentioned brands
Old Mar 18, 2004 | 12:24 PM
iNfAmOuS_E46's Avatar
those are nice as hell
Old Mar 18, 2004 | 12:27 PM
743power's Avatar
Default Re: so which camber kit is really the best? (BatuKing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BatuKing &raquo;</TD></TR><TR><TD CLASS="quote">
same as the skunk kit..</TD></TR></TABLE>
Guess who designed the skunk2 kit. . .
Old Mar 18, 2004 | 01:05 PM
silverEH2's Avatar
Default Re: so which camber kit is really the best? (743)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743 &raquo;</TD></TR><TR><TD CLASS="quote">
Guess who designed the skunk2 kit. . .</TD></TR></TABLE>
who
Old Mar 18, 2004 | 01:07 PM
precognition's Avatar
I have skunk 2 in the front and "silvers" on the rear. No issues so far.
