help! CEL 20 and car revs like crazy!
well.. i have a 91 std, and i did a MPFI swap.. it ran good.. then i blew the head gasket... went to change it, did, and put everything back together...
Now the car revs to some god sky high RPM, almost redline on a pm6. The ECU is flashing CEL 20. The throttle cable is undone from the TB, the sensors plugs have been switched around, and I'm about to LOOSE MY DAMN MIND!
HELP!
HELP!
make sure your tps and iacv plugs arent mixed up
as for eld, i had that happen to me before when i did a mpfi conversion... go look up the test procedure in helms. I ended up having to replace the whole engine bay fusebox.
http://www.binghamtonlife.com/...1.jpg
Pwnmeister
Jan 10, 2014 11:14 AM
VTgringo
11
Aug 20, 2003 04:43 AM
pelotudo
Oct 31, 2002 03:45 AM
