92 to 95 upper contral arms on 88 to 91
i wont to get the skunk 2 upper control arm camper kit but of course they don't make them for 88 to 91 so will it work. i put one of the skunks up to a stock 91 control arm and it looks like it will work it may put the ball joint back a little.
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
90-91 UCA have replaceable ball-joints. SPC makes adjustable ball-joints for that year. If you insist on getting the entire arm, look into Vision UCA, which sport similar set up as skunk2 set up.
stan
stan
I'd get the SPC ($160 pair)...adjusts camber and caster...Vision although JDM only adjusts your camber ($320 @ jhpusa.com)
if you do opt out for the bling vision (how does one bling something out of sight) you can get caster adjustable radius rods bushings.
stan
stan
i forgot to say im getting them throw the shop i work at but thanks for opening my eyes to some other brands i didn't know where out there do you have any web sites that i can look at if not i thank i can find them thanks for the info.
One more thing before I go looking and find out that I already have them. I do have a camber kit that replaces the part of the upper control arm that bolts to the frame. But this winter I kind of got ran off the road and after replacing all of my suspension in the fount the camber on the fount left if still way off even with the camber adjustment all the way out that is why I'm looking for something that will work with the camber kit I already have.
http://www.spcperformance.com/
http://www.jhpusa.com/catalog/...d=439
If your camber is out of whack, consider looking into what is causing it. most likely a bend control arm.
stan
stan
ya like I said I have replaced everything the upper and lower control arm the spindle inner and outer tie rod ends the big cross member that the lower control arm bolt to.
Its part of the frame there is a little bit of paint that is chipped off my engine bay on the wheel well where the frame got tweaked a little.
i thing im going to get the SPC ball joint thanks for the info i like when i get good info and not alot of bullshit
Thanks
Modified by 15psi of fun at 4:19 AM 3/19/2004
Thanks
EF9SIRJeff
May 31, 2006 04:35 PM
