fell asleep driving - now have some damage
Old Mar 17, 2004 | 07:59 PM
joek84's Avatar
Default fell asleep driving - now have some damage
I was going north on the turnpike and fell asleep for a second. Im lucky as hell, i coulda flipped if i went in the median of i95 or if i went right instead of left. I hit the cement divider on the left side. I only hit my wheel before i got it off the wall. I have hardcore curb damage on the front left and some on the back left wheel but no body damage. Im gonna have it checked by a shop tommorow, but i was wondering what anyone might think it is. When i turn the wheel left I hear a howling. Other than that and my whacked alignment, it drives fine
Old Mar 17, 2004 | 08:21 PM
HiRevn's Avatar
Default Re: fell asleep driving - now have some damage (joek84)
You weren't the same guy that was driving the 18 wheeler that flipped on 95 yesterday were you? JK
You're lucky that's all that got damaged. Hopefully it's just cosmetic. Get some rest bro.
Old Mar 17, 2004 | 08:43 PM
joek84's Avatar
Default Re: fell asleep driving - now have some damage (HiRevn)
that got cleared up right as i hit west palm yesterday on my way to miami from st lucie
Old Mar 17, 2004 | 08:44 PM
joek84's Avatar
why would i get howling from around my wheel when turning? damaged rotor maybe?
Old Mar 17, 2004 | 08:58 PM
shamoo's Avatar
Will you make something up for me please?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joek84 &raquo;</TD></TR><TR><TD CLASS="quote">why would i get howling from around my wheel when turning? damaged rotor maybe?</TD></TR></TABLE>
Sometimes if there is a bad impact, your wheel bearings might crap out. They make a "howling" noise sometimes.
Old Mar 18, 2004 | 07:24 AM
reno96teg's Avatar
could be that you damaged the wheel bearing.
Old Mar 18, 2004 | 07:36 AM
W.O.P.'s Avatar
Default Re: fell asleep driving - now have some damage (reno96teg)
i fell asleep once and ended up takin my teg in the grass median only to almost recover back on the highway but i was spinning to much and clipped my passenger side rearend on the concrete divider. sucked *****. looks perfect now though!! driving+sleeping= one fucked up teg
Old Mar 18, 2004 | 09:15 AM
LostAndFound's Avatar
I agree wheel bearing. Does it do it when your going straight as well. WHen mine busted at about 60 mph it would start
Old Mar 18, 2004 | 09:32 AM
Chaos69's Avatar
Default Re: (LostAndFound)
Drink some coffee next time.. I'm glad your ok though.
Old Mar 18, 2004 | 09:57 AM
Medek's Avatar
Default Re: (Chaos69)
did you check your a-arms, control arms etc. etc. and mounting points for damage/signs of impact..? (all the supporting wheel bars) i had an encounter w/ a curb once and i ever so slightly bent the bars holding the tire/rotar assembly & i pushed back the mounting points on the frame
Old Mar 21, 2004 | 06:51 PM
joek84's Avatar
Default Re: (Medek)
Alright, I had it checked up. They said they didn't know what was wrong, damn tire kingdom mechanic. They recommended i get new pads, rotors, and front calipers. I still gotta call and talk to the guy that looked at my car. I got an alignment done and the car pulls to the left. They said something's rubbing, prob my rotor. On the front corner of the rotor there's orange stuff. It's not on any of the other calipers. They said nothing was bent. Anyone have any ideas? Im planning on replacing the rotors and pads anyways. You really think i need new calipers? they seem to be braking fine.
Old Mar 21, 2004 | 07:00 PM
631 Teggy's Avatar
Default Re: (joek84)
It may also be your wheel bearing or cv joint... It would seam like a bump like that could damage either... When a car pulls to one side it is usually the cv joint...
Old Mar 21, 2004 | 07:35 PM
xplanetearth420x's Avatar
Default Re: (631 Teggy)
its either your bearings or your cv joints
Old Mar 21, 2004 | 07:57 PM
hadehatch's Avatar
Default Re: (Medek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Medek &raquo;</TD></TR><TR><TD CLASS="quote">did you check your a-arms, control arms etc. etc. and mounting points for damage/signs of impact..? (all the supporting wheel bars) i had an encounter w/ a curb once and i ever so slightly bent the bars holding the tire/rotar assembly & i pushed back the mounting points on the frame </TD></TR></TABLE>
same thing happend to me.. it doesnt take a lot to bend something in your suspension... i slid head on into a curb at around 15-20 mph.. right lower control arm was bent and so was the frame where the control arm bolted on to...
Old Mar 22, 2004 | 05:14 AM
patdemps's Avatar
Default Re: (xplanetearth420x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xplanetearth420x &raquo;</TD></TR><TR><TD CLASS="quote">its either your bearings or your cv joints</TD></TR></TABLE>
Thats what I am thinking aswell. Goodluck with it man.
Im glad your ok
Brandon04GT
11
Apr 7, 2013 07:19 PM
Spo0NFed E M 1
Suspension & Brakes
May 19, 2006 06:16 PM
r3000
Dec 20, 2004 09:29 AM
The Hooligan
10
Sep 3, 2004 05:18 PM
2000 Integra R #760
Oct 23, 2002 09:49 AM
