wire diagram
Old Mar 17, 2004 | 07:32 PM
EF-21's Avatar
Default wire diagram
okay i am trying to find my vss on my b16a ecu pr3. now which diagram do i follow 88one or do iuse a del sol
Old Mar 17, 2004 | 07:51 PM
ThatRicerDaniel's Avatar
Default Re: wire diagram (EF-21)
you dont have a electronic vss.
Old Mar 17, 2004 | 07:54 PM
EF-21's Avatar
Default Re: wire diagram (NitrousDreamz)
yes i do off an 92 civic i use it for my sir cluster i instaled but i still get code17 but the speedo works fine but the codes still comes out NO VTEC
Old Mar 17, 2004 | 08:48 PM
EF_LSVtec's Avatar
Lead wire from your VSS must be wired to the ECU (PR3) pin B-16 and a wire must also be connected from your ECU to the back of your speedometer (VSS)...
90_civic_Si
Nov 24, 2009 06:13 AM
gotgsrvtec
Dec 1, 2007 08:16 PM
hatchyboy89
Feb 2, 2006 06:00 AM
Hyaboosta
Jan 11, 2005 05:48 PM
mhx
Oct 11, 2002 08:46 AM
