Sway Bar Question
There are two different kinds of sway bars for the 92-95 civic, the one for civics with a front sway bar and one for civics without the front sway bar. Whats the difference? I heard the CX lower control arms don't have the hole to attach the sway bar to. Is this true? So how do you attach the aftermarket sway bars on a CX? DO you have to use brackets? Is using the brackets not as good as using the holes? Thanks for any info
The set for cars with a front sway bar use the stock mounting hardware and just supply the bar, bushings, and endlinks. The set for cars with no front bar include everything. Peace.
ilvi3tkidxx
Feb 27, 2009 01:24 AM
