valve springs
Old Mar 17, 2004 | 06:01 PM
dc5rwannabe's Avatar
Default valve springs
although they have different part numbers...are the valve springs different when it comes to the intake side and exhaust side?
Old Mar 17, 2004 | 06:28 PM
rsxmachine's Avatar
stock ones, yes, and it also depends which year you model you have.
the Toda ones are all the same for both sides.
Old Mar 20, 2004 | 10:53 PM
allmotor-s's Avatar
Default Re: (rsxmachine)
Hey, just curious, how much do those springs go for and how much would it cost to have them installed? That way when I get hondata #4 i can hit 8600 all the time or atleast more often.
Old Mar 21, 2004 | 05:31 AM
nickzed20's Avatar
Default Re: (allmotor-s)
the toda springs are like $400. If you are using the stock cams, then just get some S2K valve springs for like 100 bucks, since they are slightly stiffer then stock. As for install, you could probably do it yourself if you have the tools.
Old Mar 21, 2004 | 07:22 PM
rsxmachine's Avatar
I don't think you'd necessarily want Toda valve springs with the stock or ITR cams, as they are designed for higher lift.
there are plenty of ppl running around with Hondata-4 and stock valvesprings without problems, I had it for 7 months; Hondata picked 8600 because they were comfortable that the stock valvetrain could handle it.
ITRFreddy
Dec 20, 2004 10:34 PM
nsx-Animal
Sep 24, 2001 08:18 PM
