shocks/struts for 1988 HF
Old Mar 17, 2004 | 05:56 PM
junkyardRx's Avatar
Default shocks/struts for 1988 HF
does is make a difference which ones i get for the front? i know it's specific that i can only use 88s for the rear. (or is it also different if it's si/dx/hf?) it's been pretty confusing since 88 hfs are always a diff. selection from 88-91s in stores. anyways, sometimes there's good deals comin around for used ones but i want to see if i can get any 88-91 shocks/struts(which is it?) for the front. thanks. by the way i already searched but i answer i need is specifically for my hf with front 90 axles/knuckles/hubs if that matters. thanks.
Old Mar 17, 2004 | 07:21 PM
Attoir's Avatar
Default Re: shocks/struts for 1988 HF (katsumoto)
ALL 88 Civics / CRX's have the same type of rear LCA, which is different from 89-91.
You can only use 88 rear struts, correct.
You can use any 88-91 front struts, as the front suspension is identical thru' the years. Where have you found good deals for the rear? I've been needing some, pretty badly.
Old Mar 20, 2004 | 11:08 PM
junkyardRx's Avatar
Default Re: shocks/struts for 1988 HF (Attoir)
thanks for clearing that up. about the deals i get them in craigslist.com it's some sort of online flea market here in the bayarea, ca. sometimes they show up here in there from lots of people selling off used/new parts. there was a time someone was selling some tokico blues/$80/set used for a few months. anyway thanks.
Old Apr 26, 2004 | 07:58 PM
DC2-JRSC'd's Avatar
I just got a set of konis for $75 shipped from ebay. Brand new too. Heres the seller list of items for sale. If he doesnt have anything right now give him a couple of days he will post some. http://cgi6.ebay.com/ebaymotor...ws=50
Old Apr 27, 2004 | 09:56 PM
eda6's Avatar
Get 89-91 civic/crx lower arms. 90-93 integra lower arms work too. Do this and you'll be able to use all the 89-91 rear ****. 3 bolts and the lower arm is out. Did this last week. Got rid of my GR-2's in the back. Now i'm rockin Agx's all the way around in my 88 dx hatch.
Old Apr 27, 2004 | 10:23 PM
mengo_charged's Avatar
I thought you could use Type R rear suspension stuff?
Old Apr 27, 2004 | 10:35 PM
wtsexton's Avatar
Default Re: shocks/struts for 1988 HF (mengo_charged)
You can. Also why downgrade to the 89-91 setup? Honda put it on the ITR for a reason because it kicks *** its also on all the jdm ones.
Old Apr 29, 2004 | 03:41 PM
eda6's Avatar
Default Re: shocks/struts for 1988 HF (wtsexton)
I did this so i could have kyb agx in the rear. It's easy.
Find lower arms from the 89-91 civic or 90-93 integra.
They look different but they will fit.
You will have to remove 3 bolts and then the lower arm drops.
Just make sure to use the longest bolt to secure the strut to the lca.
I didn't consider it downgrading, since it gave me more suspension options for the rear.
Email if you got ?'s.
DsMWookie
Dec 8, 2005 01:45 PM
phoQ
13
Oct 3, 2005 08:37 PM
blackcomet
Dec 5, 2004 06:27 AM
ironchef25
37
Oct 15, 2003 10:17 AM
egsick6
Jul 15, 2003 12:25 PM
