Si or HF?
What would be the advantages/possibilities to each of these versions of the stunning CRX? Im looking to put some money into this car and make it into a "Sleeper." So please enlighten me with your wisdom! Thanks!
-Jack
-Jack
depends on the year you want. 90-91 had rear disc(si), my 88Si has drums.
Si= sunroof (extra 25lbs) and are a pain. Mine is dragging and scratching the crap out of my paint.
the rear taillights changed a lil from 88-89 90-91
The seat belt changed also.
I suggest the HF, find a 88' supa light. I'm shure you'll find 1,000 things on CRX's if you do a search
Go for the HF. The ONLY thing the SI has that cannot be swapped over the HF is the sunroof. And unless you consider having a sunroof to be VERY important to your enjoyment of the car, avoid it. The bottom line: it is MUCH easier to deal with any of the shortcomings of the HF than it is to deal with the weight problem of the SI. Unless you autocross or participate in any other form of racing in which you are stuck with a stock engine, SIs are all hype and no substance.
i personally want an si because i DO consider a sunroof to be very important since it will also be a daily driver not just a track *****
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebpG2 »</TD></TR><TR><TD CLASS="quote">i personally want an si because i DO consider a sunroof to be very important since it will also be a daily driver not just a track *****</TD></TR></TABLE>
There are alot of us (like myself) who have no use for a sunroof, even on a daily driver. I guess what I meant was that unless you personally consider a sunroof to be desirable, pass on the SI. But I guess that maybe you DO consider a sunroof to be desirable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89zchf »</TD></TR><TR><TD CLASS="quote">I bought my hf with a sunroof and also a cd player. I also heard ac didn't come in an 89 hf but mine had that also. I have no backround as to how these got on the car</TD></TR></TABLE>
Do you happen to have a rear wiper, passenger side mirror, Dual Point Fuel Injection, and door mounted seatbelts? If so, then you have a DX.
hf and a sunroof..? i bought a 88 hf crx with a single cam zc motor ..im asuming that its obd0 because i run a chiped pr4 (used to have pm6) and on the intake manifold it says (pgmfi) is that the same as mpfi? back to the topic..id buy an hf again. I also have a 89 si and if lifted both clear off of the ground and the si was deffinetly heavier .. if i were to buy another crx it would be an hf...
long story short = HF
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T3 l CIVIC »</TD></TR><TR><TD CLASS="quote">There's more differences between the Si and HF than just a sunroof
I know that. But everything else can be swapped over. The electric sunroof is the only thing that the SI has that cannot easily be swapped over. And my point is that if you don't consider a sunroof to be important, it is better not to have it.
</TD></TR></TABLE>I know that. But everything else can be swapped over. The electric sunroof is the only thing that the SI has that cannot easily be swapped over. And my point is that if you don't consider a sunroof to be important, it is better not to have it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxtreme89h »</TD></TR><TR><TD CLASS="quote">
Do you happen to have a rear wiper, passenger side mirror, Dual Point Fuel Injection, and door mounted seatbelts? If so, then you have a DX. </TD></TR></TABLE>
im pretty sure rear wipers were optional...my friend with a si has no rear wiper...door mounted seat belts were on the 90-91's i believe....and ive seen dx's with both side mirrors
i've owned 4 crx's...3 were hf's and one a dx. simple answer = get an hf! after owning an hf...i asked myself, "why buy any other model?" yea yea...i know its bad to talk to yourself!
LOL
LOL
