What camber kits (F&R) do you recommend?
With all the suspension work being planned for my car, I would like some input on camber kits for F&R of my car... please give your opinion.
Unless you plan to slam the car more than 3", or if you need to dial in extra negative camber for track use, then I recommend just staying with stock parts. The toe-in can be aligned and tires rotated frequently to prevent most all abnormal tire wear. You will save money on parts, save money on the alignment, and don't have to worry about the possibility of the aftermarket parts slipping, squeeking, hitting the fenderwell, or whatever else could happen when using aftermarket camber correction kits.
<-- 25K miles on current tires w/ -2.5 camber
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FireMedic »</TD></TR><TR><TD CLASS="quote">any other thoughts?</TD></TR></TABLE>
I agree with Patrick. As long as the drop is reasonable, just have a quality alignment done after the installation (paying careful attention to toe).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">Unless you plan to slam the car more than 3", or if you need to dial in extra negative camber for track use, then I recommend just staying with stock parts. The toe-in can be aligned and tires rotated frequently to prevent most all abnormal tire wear. You will save money on parts, save money on the alignment, and don't have to worry about the possibility of the aftermarket parts slipping, squeeking, hitting the fenderwell, or whatever else could happen when using aftermarket camber correction kits.
<-- 25K miles on current tires w/ -2.5 camber</TD></TR></TABLE>
im personally running with that advice come saturday when my sports go in with the agx's...i dont want a camber kit...
btw. patrick on the oem bumpstops theres like rings,how many rings do u recomend to leave,right now the ones i have are at three rings,good enough? and are the front and rears 2 different colors? yellow and orange..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KidKat »</TD></TR><TR><TD CLASS="quote">the man asked for suggestions on camber kits, not why he shouldn't buy them
anyways...
Skunk2 front
Ingalls PolyU rear</TD></TR></TABLE>
Actually, the exact post was:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">With all the suspension work being planned for my car, I would like some input on camber kits for F&R of my car... please give your opinion.</TD></TR></TABLE>
He wanted input and opinions on camber kits. Some of the input and opinions he received suggested that the kits are quite often unnecessary, and these were perfectly valid responses.
If someone asked for opinions on unsprung clutches or sheet-metal intake manifolds for his stock GS-R, would you suggest the best ones you know of, or would you advise him that they're unnecessary and possibly even detrimental for his setup?
Modified by Padawan at 7:14 PM 3/18/2004
anyways...
Skunk2 front
i also have the skunk2 kit... i've had it for a little under a year now i think.. but i'm very happy with it. I've been lucky and had no problem with any slipping, squeaking, or other problem. Some may get away with dropping their cars and not puttin one on, but i'm glad i did mine. Thats my input.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraBoy04 »</TD></TR><TR><TD CLASS="quote">I have the Skunk 2 kit, and I really like it. It is kind of expensive, but it is worth it.</TD></TR></TABLE>
