hf with si wire harness
Old Mar 17, 2004 | 03:40 PM
aaronbb22's Avatar
Default hf with si wire harness
what is different between the wiring is the distributor wiring any different
Old Mar 17, 2004 | 04:19 PM
brent_G's Avatar
Default Re: hf with si wire harness (aaronbb22)
Old Mar 17, 2004 | 04:22 PM
brent_G's Avatar
Default Re: hf with si wire harness (brent_G)
Other then that its basically the same thing...other then the fact the hf uses the egr..
Old Mar 18, 2004 | 05:59 AM
undefinedcrx's Avatar
everything is the same except the hf has EGR which you dont need to plug in unless you still got the HF motor which im sure you dont.
Old Mar 18, 2004 | 06:21 AM
jlicrx's Avatar
as you can see from the diagram, all of the wires are in different locations on the 2 harnesses - they will plug in, but HF will not work in Si and Si will not work in HF - you need to use the harness that matches your car - also notice that on the HF, the alternator wiring runs through this connector - on the Si it is in a different connector - if you use Si harness on HF, you will have the #2 injector connected to the EACV pin-out at the ECU, #1 injector connected to the alternator signal, #3 injector connected to the EGR lift valve sensor pin-out at the ECU, etc. - it will not run without the right harness
Serdar
Aug 15, 2003 08:05 PM
pdiddyparsons
11
Nov 14, 2002 06:18 AM
91HATCH
23
Oct 15, 2002 05:03 PM
FredoTheChimp
Jun 23, 2002 09:34 PM
CimorelliCRX
Apr 18, 2002 02:14 AM
