air/fuel fact or fiction?
Old Mar 17, 2004 | 03:10 PM
SOHC50shot's Avatar
Default air/fuel fact or fiction?
I just bough an auto-meter air fuel guage for future use in my turbo set up, and i have been hearing alot of ****.
I heard from quite a few people that they arnt accurate at all, but then again some other people said they are......fact or fiction??
Old Mar 17, 2004 | 03:18 PM
M-EJ1's Avatar
Default Re: air/fuel fact or fiction? (SOHC50shot)
Nothing that uses the stock O2 sensor is going to be anything worth a **** really. To actually get something useful other than a pretty light show you'll need to step up to a wideband O2 (and you'll probably want an EGT gauge as well).
I have an autometer A/F gauge in my turbo'ed coupe and the only thing it's really good for is impressing my friends and getting them to ask me what it's for (there's a story I've told a million times... "you see, in an internal combustion engine, there's this thing called fuel, and this thing called air... blah blah blah")
BlackFrog's Avatar
i believe the accurate are the ones that go with a wideband O2 sensor. without it you end up with a nice light show.
also, using an A/f gauge like that one is kind of misleading, becaus the computer cycles the fuel mixture rich/lean for cat. efficiency. you dont really get a true measure of the A/F ratio unless something is grossly wrong, like a cracked manifold, leaky fuel injector etc.
-Chris
EDIT: wow, i got beat too.
Old Mar 17, 2004 | 03:19 PM
alloutmotor's Avatar
the air fuel gauge is useless without a wideband o2 sensor, reason being is that an regualar O2 sensor isnt accurate it just tells the computer:
Hey im rich
or Hey im Lean
ect
A wide band says to the computer,
Hey 12:1
hey 16:1
an EGT guage would help out better
edit: damn yall fast, i thought i was gonna be first
Old Mar 17, 2004 | 03:26 PM
976's Avatar
976
New User
Default Re: (alloutmotor)
Go Apex'i EGT - very accurate...
Old Mar 17, 2004 | 04:20 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alloutmotor &raquo;</TD></TR><TR><TD CLASS="quote">reason being is that an regualar O2 sensor isnt accurate it </TD></TR></TABLE>
Actually it's very accurate in the narrow a/f range it is designed to operate in.
Old Mar 17, 2004 | 04:21 PM
Ricey McRicerton's Avatar
Default Re: (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
Actually it's very accurate in the narrow a/f range it is designed to operate in. </TD></TR></TABLE>
Which is about 1/5th of the total spectrum.
Old Mar 17, 2004 | 04:28 PM
Chiovnidca's Avatar
Default Re: (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">
Which is about 1/5th of the total spectrum. </TD></TR></TABLE>
It's alot less than that I think.
RyanEJ8's Avatar
The stock o2 sensor that a regular A/F guage utilizes is a narrowband sensor. It only has a range of 0-1 volts. Basically it was only engineered to tell you if the engine is running at stoichiometric conditions (14.7:1). This Stoich level isn't even what you would tune a boosted or nitrous car for, this would only apply to an N/A tune.
A wideband o2 can read from 0-5 volts and gives a much more accurate reading. This is engineered to be accurate and read air/fuel at different levels than stoich (rich or lean).
In other words, air/fuel guages are pretty much useless and don't really work. Check into the AEM Wideband o2 guage. It's a little more pricey (about $440), but it actually works.
Old Mar 17, 2004 | 04:31 PM
It's alot less than that I think. </TD></TR></TABLE>
It's either 1/5 or 1/6. I read all about WB02s before I bought mine. I can't remember what site it explained it all either..damn...
Old Mar 17, 2004 | 04:35 PM
RyanEJ8's Avatar
It's either 1/5 or 1/6. I read all about WB02s before I bought mine. I can't remember what site it explained it all either..damn...</TD></TR></TABLE>
Based on the post that I just made above about narrowband being 0-1 volt and wideband being 0-5 volt, I guess you could kind of say it is 1/5th accurate.
KStuned
Oct 6, 2004 11:39 AM
RACEPAK
Jul 27, 2004 04:24 PM
swlabhot
Jan 20, 2003 06:50 AM
