b18a what axles serious probs
http://www.hondaswap.com/forum...&st=0 i need some help here thanks
chris
chris
Is it smaller hub side? If so, you may need new hubs from a DX or SI. I think you will need the calipers too. You might as well do what I did and replace the whole setup with that from a DX or si.
Sounds like someone ghetto rigged their axles for the B18 swap.
Does it even look like it will fit? It does take a bit of screwing with it to fit into the hub side if you have DX or SI hubs. Try putting it through the other side of the Hub. If you can get it in that side then it will fit. You just have to mess with it a bit.
Try measuring the diameter of the hub hole and the diameter of the axle "hub side". If they are the same size it will fit. If the hub hole is smaller it definitely won't fit. If it won't fit, you will need DX/SI hubs. It's not that hard to replace the hubs.
Also, if the hubs on your car are the same size as the axle then try putting some axle grease on there to get it to slide in place. If you tried the axle on both of your cars, then it sounds like you aren't trying hard enough or you are cursed with smaller hubs on both of your cars.
PS. I don't have aim but you can IM me here.
i still cant get it to fit for some reasonl..like how much of fooling with it does it take??..i know this one is a dx for sure...but for some reason i cant get it in there and i am geting frustraded
Try kinda twisting it back and forth as you are pushing it in. I don't know what else to say man. I understand the frustration.
You are probably at your post limit so click the IM icon below this:
5 posts [100%]
newburgh ny
3-17-2004
Modified by crxtreme89h at 11:43 PM 3/17/2004
5 posts [100%]
newburgh ny
3-17-2004
bossman032
13
Apr 20, 2003 09:48 AM
