ef to si
Old Mar 17, 2004 | 02:01 PM
Bob_Digi's Avatar
Default ef to si
i jsut bought an 89 ef i have an 89 si motor sitting here, will the si motor fit on the ef tranny?, and is it pretty strait forward of are there a few wiring issues?
Old Mar 17, 2004 | 02:05 PM
Targa250R's Avatar
be professional
Default Re: ef to si (bob evans)
What model of '88-91 Civic do you have? The base hatchback? The DX?
The '89 Si engine you have is stamped "D16A6," right?
Old Mar 17, 2004 | 03:45 PM
kranked91dx's Avatar
Ef is a body code man,
you got EF: dx, si, cx.
your d16a6 engine will fit in there like a glove, the only exception is transmisison wise, the 88 got a spline less than all his common brother, you can do a wiring conversion, it's easy, you will however need the d16a6 ECU in there.
try searching : wiring convertion or Wiring in the EF section you'll come up with plenty of result for your convertion.
see ya
good luck
KRanked
Old Mar 17, 2004 | 06:38 PM
Bob_Digi's Avatar
sorry about the shitty question what i have is a crx hf with a blown motor, i have a d16a6 replacement motor what is all need to make it work anbd will the 89 hf tranny bolt up to it
Old Mar 17, 2004 | 08:51 PM
EF_LSVtec's Avatar
Default Re: (bob evans)
Yes it will bolt up and so are the wires because HF is MPFI too...
Old Mar 17, 2004 | 09:18 PM
Bob_Digi's Avatar
can i use the hf ecu or will i need the a6 ecu??????
Old Mar 17, 2004 | 09:26 PM
Origin's Avatar
yeah the hf will bolt up, but i believe it has really crappy gear ratios. you might want to search on that or someone should give some more insight on it.
Old Mar 18, 2004 | 12:55 AM
Mr_CRX's Avatar
Default Re: (Origin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Origin &raquo;</TD></TR><TR><TD CLASS="quote">but i believe it has really crappy gear ratios.</TD></TR></TABLE>
very true. 5th gear at like 90-95mph is only revvin' like 3k rpms in my friends HF.
the tranny will bolt up, but it would be a VERY good investment if you could get an SI tranny to go along with that motor. even a DX one will be a lot better than the HF. hope that helps a little!
Old Mar 18, 2004 | 01:47 AM
payneth's Avatar
Default Re: (Mr_CRX)
90mph at 3k sounds good to me. lol toobad it isnt as god as it sounds
swordofdoom
Sep 20, 2012 05:33 AM
Lewy. Dee Ayy
Jul 3, 2007 08:55 PM
vegaskurt
Feb 10, 2005 11:43 AM
