OBD1 MAP sensor pin?
Old Mar 17, 2004 | 01:02 PM
poid's Avatar
Default OBD1 MAP sensor pin?
Hey guys, which pin is the MAP sensor on an OBD1 p0a ECU? The workshop manual i have says it is D19 (though this manual is for the CD7-9, i would expect no difference to a CD5). However, using this pin i just get a constant 4.5ish volts from it no matter what according to my datalogs. This is obviously not right!!
Other OBD1 ECU's seem to have it on D17 i think?
Cheers
Old Mar 17, 2004 | 03:55 PM
Chiovnidca's Avatar
Default Re: OBD1 MAP sensor pin? (poid)
Not sure on a P0A. On a P28 d17 is sensor input, d19 is ref voltage, and d21 is sensor ground.
Old Mar 17, 2004 | 04:55 PM
poid's Avatar
yeh i'm thinking its D17, as when going to P28 tehre is no need to change any pins other then A6 and A11...
D19 being ref voltage makes sense as well
Old Mar 17, 2004 | 11:19 PM
poid's Avatar
OK, D17 looks like its working great
Now, the next question...i've thrown a CEL, and when i jumpered it the ABS light started flashing, not the CEL. Is this normal?
Old Mar 18, 2004 | 03:41 AM
Chiovnidca's Avatar
Default Re: (poid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poid &raquo;</TD></TR><TR><TD CLASS="quote">when i jumpered it the ABS light started flashing, not the CEL. Is this normal?</TD></TR></TABLE>
Yes, if it's a constant steady flash there is no problem. Or is it flashing a code?
Old Mar 18, 2004 | 01:01 PM
poid's Avatar
looks like its flashing a code...there's 2 flashes, a pause then on flash, does that 3 times
The CEL doesnt flash at all
Old Mar 18, 2004 | 01:09 PM
Chiovnidca's Avatar
Default Re: (poid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poid &raquo;</TD></TR><TR><TD CLASS="quote">looks like its flashing a code...there's 2 flashes, a pause then on flash, does that 3 times
That would be a code 2-1. I'd clear it and see if it comes back.
Old Mar 18, 2004 | 02:48 PM
poid's Avatar
comes back each time with the chipped ECU (p28 running Uberdata), but not the stock p0a
I best double check everything, i am sure the bin is OK though
BlueRex1020
Mar 17, 2007 09:28 PM
dek1mfk
Nov 7, 2006 07:39 AM
MDPL8706
Jul 12, 2006 06:31 PM
menappi
Jul 2, 2006 06:31 PM
