Where is my CPS
Old Mar 17, 2004 | 12:03 PM
s2kkk's Avatar
Default Where is my CPS
Working on my mpfi swap i got the last two wires here is what it says to do ...For SOHC engines such as the Si
-Connect the C1 wire to the blue/green wire on the CPS (the sensor is inside the Distributor on a SOHC engine). For doing this I suggest swapping out to the proper Si distributor plug so it is all plug and play and looks clean.
-Connect the C2 wire to the blue/yellow wire on the CPS.
Where is the CPS?
Old Mar 17, 2004 | 01:49 PM
Doctor CorteZ's Avatar
Default Re: Where is my CPS (spoon.eg)
MPFI distributor has the wires you're looking for coming out of it.
CPS = crank position sensor , FYI.
Old Mar 17, 2004 | 02:22 PM
crx_88_si's Avatar
Default Re: Where is my CPS (Doctor CorteZ)
ya it's in the dist.
89ED
Jun 16, 2016 11:36 AM
Adam_0115
Apr 14, 2016 05:11 AM
Tippyman
13
Apr 11, 2006 09:05 AM
ranta18
10
Nov 21, 2003 06:13 AM
