Tranny Oil change question?
Ok, here we go. When u change your tranny oil, do u also change the filter? Or do you just drain the old and pour in the new? Do I need impact tools to get them bolts off? Do I need a funnel/hose? More like 4questions! Thanks!
umm...the tranny doesn't have a filter. so just basically drain it from the 3/8 drive bolt torwards the bottom. you shouldn't have to use air tools. just a good size wrench and some strength and it should come off. just get a long funnel and pour in your new tranny fluid through the vehicle speed sensor. if you don't know where the vss is check the FAQ section in the eg/del sol forum. the moderator there did a good write up on how to change your tranny fluid.
db8sirg
Feb 18, 2004 06:04 AM
