Input shaft bearing gone mad?
Old Mar 17, 2004 | 11:38 AM
mmuller's Avatar
Mad Scientist
Default Input shaft bearing gone mad?
This is for a honda Passport ( i know is an izusu rodeo, but...). Makes the infamous helicopter noise; real bad.changed the tranny fluid and had some metal in it.
It also stops when the clutch is pressed in, just like the release bearing would do.
It also does it in all the gears and when down shifting....BUT 4th, in 4th is smooth as new...WTF
Im thinking is the input shaft bearing.Any tips? the 4th gear being ok just throws me off..
thanks
Old Mar 17, 2004 | 06:21 PM
mmuller's Avatar
Mad Scientist
Default Re: Input shaft bearing gone mad? (mmuller)
ttt
somebody knows about rwd tranny's
Old Mar 17, 2004 | 07:14 PM
Dan GSR's Avatar
your assesment sounds right
what happens is that when that bearing goes bad the gears aren't lined up perfectly, so when torque is applied to it, it makes that nasty sound
when you press in the clutch, it is releasing the energy that was being exerted on that main shaft, so the sound goes away
if the problem is not addressed the transmission will just get worse and worse
not sure if this applies for this car, i know that, that is the case with B series
Old Mar 17, 2004 | 07:51 PM
mmuller's Avatar
Mad Scientist
Default Re: Input shaft bearing gone mad? (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">your assesment sounds right
not sure if this applies for this car, i know that, that is the case with B series</TD></TR></TABLE>
yeah, your right, but what i was wondering why it does not make noise in 4th gear.weird
kami6666
Transmission & Drivetrain
Feb 25, 2011 12:13 AM
1kleenef
Apr 13, 2008 11:12 AM
1kleenef
Apr 1, 2008 05:04 AM
HomicidalHatchBack
10
Nov 11, 2006 05:47 PM
stephen_civic98
Jan 9, 2006 06:05 PM
