suspension problems.
Old Mar 17, 2004 | 10:47 AM
SM 30 Hatch's Avatar
Default suspension problems.
I am an avid autoxer and I had an event this past weekend where I experienced some problems with my tire/wheel/suspension package. I would like to explian my problem to you and see if you have a product or suggestion to that could possibly allivate this.
Car:
1991 Honda Civic Dx Hatchback
Mods:
Tokico Blue (nonadjustable) dampers
Coilovers (450/350 lb springs)
Rear Disc conversion from a 1993 Acura Integra
Rear Sway Bar from a 1993 Acura Integra
Front suspension minus the dampers and coilovers is stock.
Tires and Wheel:
215/50/13 Khumo Ecsta V700
13" Kisers
Problem:
During a hard left hand turn (90-180* turn) under braking, the tire would pop off the bead. My co-driver for the even believes it might be a caster problem. I was wondering if you have ever heard of this problem or know of a solution to this problem. I do not have the problem when I'm running the 195/60/14 Falken Azenis on stock 14" steelies. Do you think adjusting the caster would solve this problem ? If so would I have to use your adjustable radius rods to do so ?
any input from you would be very valuable and helpful.
Thanks,
Scott
Old Mar 17, 2004 | 11:15 AM
byathread's Avatar
Default Re: suspension problems. (integen1)
is the camer alligned correctly?
Old Mar 17, 2004 | 11:17 AM
johnjw's Avatar
Tire comeing off=very dangerous, if thats your problem then its a tire fitment issue, what psi are you running?
Old Mar 17, 2004 | 12:27 PM
Default Re: suspension problems. (johnjw)
36 psi up front 34 in the rear..
Old Mar 18, 2004 | 06:08 AM
undefinedcrx's Avatar
i think its a tire fitment issue also. how wide are the rims?
Old Mar 18, 2004 | 06:36 AM
crx_88_si's Avatar
Default Re: suspension problems. (undefinedcrx)
215 on 13"!!! i bet the rims are 13x4 or 13x5.. waaayyy to narrow.
get 14's.
recomended rim width is 6.5+ for a 215.
215mm=8.5"
Old Mar 18, 2004 | 08:51 AM
Default Re: suspension problems. (crx_88_si)
they are 13x7.. they make 13x8 and 13x9..
Ahleks727
Suspension & Brakes
Oct 10, 2014 04:07 AM
djtsmith007
Oct 16, 2009 04:44 PM
Roybal 3
Suspension & Brakes
Apr 17, 2009 10:20 AM
mr. robot-o
Aug 25, 2008 02:04 PM
SM 30 Hatch
Mar 18, 2004 05:41 AM
