what parts am i going to need
Old Mar 17, 2004 | 09:22 AM
1SOL2NV's Avatar
Default what parts am i going to need
i have 94 del sol si and am planning on putting in 98 ex engine in do i need to change ecu dizzy or can i use all the stuff off my stock engine thanks for the help
Old Mar 17, 2004 | 09:23 AM
SOHC_MShue's Avatar
Default Re: what parts am i going to need (1SOL2NV)
why would you do that? Your engine is basically the same thing.
Old Mar 17, 2004 | 09:29 AM
skip.two's Avatar
Default Re: what parts am i going to need (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">why would you do that? Your engine is basically the same thing.</TD></TR></TABLE>
Old Mar 17, 2004 | 09:31 AM
jameskersten1's Avatar
Default Re: what parts am i going to need (jL iLLuZiOnz 9)
kinda dumb move if you ask me, but you will need to convert from obd2 to obd1 i believe, you can get a harness jumper for that, other then that SHOULD be the same
Old Mar 17, 2004 | 09:35 AM
1SOL2NV's Avatar
because stock engine has a spun bearing
i was told that it was a drop in without needing anything else.
Old Mar 17, 2004 | 09:36 AM
Ricey McRicerton's Avatar
Id say just find another Z6. The Y8 will be more trouble than it's worth IMHO.
Old Mar 17, 2004 | 10:11 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">Id say just find another Z6. The Y8 will be more trouble than it's worth IMHO. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SOL2NV &raquo;</TD></TR><TR><TD CLASS="quote">because stock engine has a spun bearing
i was told that it was a drop in without needing anything else. </TD></TR></TABLE>
it basically does drop in the same but the hassle of changing over certains things, you could just buy a z6 cheaper then a y8 and have half the hassle
Old Mar 17, 2004 | 10:24 AM
hatchi's Avatar
what have you gotten so far?? hit me up if you need help
Old Mar 17, 2004 | 10:29 AM
SOHC_MShue's Avatar
just pick up another z6. Why a y8?
Old Mar 17, 2004 | 10:31 AM
1SOL2NV's Avatar
Default Re: what parts am i going to need (jameskersten1)
what all needs to be changed over
Arturo Sanchez
Nov 29, 2012 10:41 AM
sde780
Oct 13, 2009 04:54 PM
1991hb
Mar 14, 2007 08:30 AM
moonmoney20
Jun 22, 2006 10:47 AM
b18c inside
Apr 14, 2005 05:12 AM
