CEL 08. TDC sensor??? What to replace???
Old Mar 17, 2004 | 04:51 AM
stehigs321's Avatar
Default CEL 08. TDC sensor??? What to replace???
Hey i heard i need to replace the distributer sub assembly. What exactly is this. The part that bolts to the head that the dist. cap is screwed onto? How much do these cost. Anyone have one for a 98 gsr. Or is there anyway to troubleshoot this code. I recently had my rotor and cap changed. would this be affecting it? what else should i look for, timing?
Old Mar 17, 2004 | 05:03 AM
stehigs321's Avatar
Default Re: CEL 08. TDC sensor??? What to replace??? (stehigs321)
bump please help
Old Mar 17, 2004 | 05:04 AM
Disco_Stu's Avatar
It's teh cam angle sensor in the dizzy that needs to be replaced; that is of course if you have confirmed that the timing is on. HTH
Old Mar 17, 2004 | 05:14 AM
EE_Chris's Avatar
#4 in the pic is the sub-assembly/housing. Its ~$240 from most online places. You will have to swap over parts 3, 5, 7, and 10 from your old dizzy.
Old Mar 17, 2004 | 08:35 AM
stehigs321's Avatar
Default Re: CEL 08. TDC sensor??? What to replace??? (EE_Chris)
so i pretty much need to change my hole distributor. Atleast get a hole new part were all the wires come out. Correct??
Old Mar 17, 2004 | 08:58 AM
EE_Chris's Avatar
Yes....assuming that is the real problem....
Old Mar 17, 2004 | 10:26 AM
hatchi's Avatar
yes dist. did you do some wiring work lately?
Old Mar 17, 2004 | 11:13 AM
stehigs321's Avatar
Default Re: CEL 08. TDC sensor??? What to replace??? (hatchi)
no wiring work. what wires should i look for if there wasanything wrong with them? Coming from the dist.?
Old Mar 17, 2004 | 03:00 PM
stehigs321's Avatar
anyone know. I did recently clean my engine bay, and also moved some wires to have less clutter. What should i look for??
Old Mar 18, 2004 | 04:10 AM
stehigs321's Avatar
please help
Old Mar 18, 2004 | 05:11 AM
EE_Chris's Avatar
As I suggested in your other thread, you need a timing light. Also look at my sig for additional help in troubleshooting.
Old Mar 21, 2004 | 12:43 PM
EKhothatch's Avatar
I am currently having this problem and I did wiring. All I did was soder the Blu & Blk/Yel wire on the dist. Could that be the problem? I also changed cam gears and changed the t-belt.
Efabe
May 11, 2017 06:23 AM
95whitej
Sep 17, 2010 12:28 PM
DUKE LADUKE
Apr 15, 2010 12:57 PM
trevorjohn88ef
Dec 26, 2008 02:55 PM
hybridEj6
Sep 11, 2003 06:41 PM
