ECU code: 54 CKF Crankshaft Fluctuation Sensor HELP
Hi, a while back i was driving and a cel popped up. I pulled the code and was given 54, which is the CKF crankshaft fluctuation sensor according to my haynes. Should I start looking for a new sensor or is there a way to trouble shoot this? As far as i know, the sensor is located under the lower timing belt cover? Anyone who's had this code, can you give me some advice? prices on parts? Thanks
Edit: this is on an obd-IIa 1998 civic dx hatchback with a d16y7.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundbomber »</TD></TR><TR><TD CLASS="quote">Hi, a while back i was driving and a cel popped up. I pulled the code and was given 54, which is the CKF crankshaft fluctuation sensor according to my haynes. Should I start looking for a new sensor or is there a way to trouble shoot this? As far as i know, the sensor is located under the lower timing belt cover? Anyone who's had this code, can you give me some advice? prices on parts? Thanks
Has the timeing belt ever been replaced? Check the wires where they run past the alternator belt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundbomber »</TD></TR><TR><TD CLASS="quote">replaced about 30000 miles ago for the major service, that's about it</TD></TR></TABLE>
Check the wires, they may be rubbing on the alternator belt.
Oh, before this cel i had one for the primary o2 sensor and after i swapped that out for a new one. I showed this code
looks like i'ma have to invest in a new sensor, any body have any tips as to how to check if the current one is dead? and how much a new one costS?
Part #14: $27.50
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundbomber »</TD></TR><TR><TD CLASS="quote">any body have any tips as to how to check if the current one is dead?</TD></TR></TABLE>
Check sig.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundbomber »</TD></TR><TR><TD CLASS="quote">looks like i'ma have to invest in a new sensor, any body have any tips as to how to check if the current one is dead?
It should measure 1600-3200 ohms between pins one and three at the connector.
Check for shorts to ground too.
C4st0r_Tr0y
Honda Civic (2001 - 2005)
Aug 12, 2018 08:08 AM
