ECU wiring and o2 sim gurus help!!
Old Mar 17, 2004 | 02:47 AM
ATS*Mark's Avatar
OG triple OG
Default ECU wiring and o2 sim gurus help!!
sup , im wondering if anybody knows how the o2 simulator heater works....how is it heated . and what are the heater wires from the ecu , i need to put a resister on there for the o2 sim and i dont have a secondary o2 harness anymore . im under the impression that both those black wires are grounds , one goes to the ecu and together they create heat . correct me if im wrong . but i need this so i can get rid of me CEL . thanks
Old Mar 17, 2004 | 05:08 AM
EE_Chris's Avatar
Default Re: ECU wiring and o2 sim gurus help!! (Hella_JDM)
The two black wires are for the heater section. One wire is a switched +12v, while the other wire is a 'controlled' ground through the ECU. I say controlled, because from what I understand, the ECU does not always supply a constant ground...its more of a PWM signal.
The heater element inside the O2 sensor has a resistance of 15-40ohms, as spec'd by the Helms. If your going to use a resistor here, you need a high wattage one.
hondaNoober
Dec 26, 2015 08:18 AM
h0nda n00b
10
Jan 17, 2012 10:20 PM
94DCTeg
Jun 21, 2008 01:00 PM
Ls1 FD3s
Aug 27, 2007 06:44 PM
smkngsr
Jun 4, 2002 12:22 PM
