clean injectors
Old Mar 16, 2004 | 10:55 PM
HXvtec's Avatar
Default clean injectors
ran outta gas the other day and now my car kinda bogs goin to 2nd. it was doing that when i was low of gas also. everytime i shifted i jerked forward thats how bad it was. i think its my injectors. what should i use to clean them. is alcohol safe??
Old Mar 16, 2004 | 11:22 PM
Louie_EM1
Guest
Posts: n/a
Default Re: clean injectors (HXvtec)
woah; don't clean em yourself man.
It's suggested to get em blanced and flowtested and then cleaned - oh, and by a licenced professional.
Look in your yellowpages to see if you have any fuel-injector places; they can do all kinds of vehicle fuel managements.
It should be about 15-20 bucks per injector.
The process take's about an hour and you'll get it back with a spread sheet of how many CCs and ohms.
If they're stock you want them to be around 240cc (mine was 249) and about 17ohms(I am pretty sure)
Old Mar 16, 2004 | 11:27 PM
HXvtec's Avatar
Default Re: clean injectors (Louie_EM1)
i needed to be a little more specific. i mean what can i put in the tank that will clean them??
Old Mar 16, 2004 | 11:39 PM
Louie_EM1
Guest
Posts: n/a
STP fuel injector cleaner; go to an autostore and start reading lables. There are a few to choose from. Good luck
Old Mar 16, 2004 | 11:47 PM
HXvtec's Avatar
thanx y0
Old Mar 17, 2004 | 03:58 AM
JimmyAtlantis's Avatar
Get the STP in the ORANGE bottle ! If you completely emptied your tank you may have sent some rust into your lines. Yes, rust can end up in the fuel tank. Run that **** in the ORANGE bottle through a couple tankfuls of 93 octane and you should be good to go.
Old Mar 17, 2004 | 04:27 AM
stackz's Avatar
at the jetties fishin'
Community Builder
Default Re: clean injectors (JRI94)
you can always buy a fuel injector screen kit from the parts store too.
might have some debris on the inlet screens. kit comes with new o-rings and screens. pop the injectors out, use tweesers to pull out the old screen and then put the new one in and swap the o-rings.
good to go.
movingIIshadow
30
Feb 29, 2020 07:36 AM
lildevock
Aug 18, 2004 10:07 PM
asianspeed
Mar 6, 2003 02:35 AM
allmotorls95
Feb 3, 2003 09:01 PM
michaelpr
Dec 6, 2001 06:06 PM
