Can you use stock valvetrain with Buddy Club Spec III Camshafts?
Old Mar 16, 2004 | 10:19 PM
JDM TypeR 307's Avatar
Default Can you use Stock Valvetrain with Buddy Club Spec III Cams ?/
Specs:
Specifications: intake 304 duration, 11.59 mm lift, exhaust 294 duration, 10.71mm lift
Can you use it wht ITR Valvetrain?
Old Mar 17, 2004 | 03:45 AM
who00knows's Avatar
Default Re: Can you use Stock Valvetrain with Buddy Club Spec III Cams ?/ (JDM TypeR 508)
where did you find these camshafts??? who sells them?
Old Mar 17, 2004 | 04:11 AM
00MRSi's Avatar
Default Re: Can you use Stock Valvetrain with Buddy Club Spec III Cams ?/ (who00knows)
Omniman has a set of theses cams. I think he is gonna install them this week.
Old Mar 17, 2004 | 07:44 AM
rodimus's Avatar
Default Re: Can you use Stock Valvetrain with Buddy Club Spec III Cams ?/ (00MRSi)
look in the all motor forum.
someone else already started a thread about it and omniman stated his dyno results vs. dynamic autosports A cams and CTR's.
gains were impressive...even on the trackmasters dyno which is like "9340932049" feet above sea level, and reads now as hell.
omniman has the portflow valvetrain, which we all know is itr outters and their inner springs (also same as alaniz)
so all you guys with type r's already, just run portflow inners. for 80 bucks you can't beat it, and you should be able to run 9000+ rpms. i know a couple of people running that valvetrain with their jun 3's.
Old Mar 17, 2004 | 07:46 AM
rodimus's Avatar
Default Re: Can you use Stock Valvetrain with Buddy Club Spec III Cams ?/ (EVOL)
https://honda-tech.com/zerothread?id=795645
GO THERE
carboy_honda
22
Mar 16, 2009 06:18 PM
1SikEagle
13
Dec 12, 2008 04:46 AM
gakkuken
Jul 23, 2004 02:42 PM
cliqueSI
May 8, 2001 08:25 PM
