Strut bars or sway bars?
Old Mar 16, 2004 | 09:27 PM
AccordCD5's Avatar
Default Strut bars or sway bars?
Strut bars and Sway bars, whats the diffrence? Adding these componets will result in slight oversteer or understeer right? Can someone explain under, and oversteer for me? Thanks
Old Mar 16, 2004 | 09:52 PM
The_Todd's Avatar
Farts in the shower
Default Re: Strut bars or sway bars? (AccordCD5)
please search and here is all your handling issues:
https://honda-tech.com/zerothread?id=796414
Old Mar 16, 2004 | 10:00 PM
matix's Avatar
I like your bling vrdrvr yea search its your answer to all questions
Old Mar 16, 2004 | 10:42 PM
azian21485's Avatar
quick break down:
sway bar reduces swaying of the body..this combined with the correct spring rates is what affects over/under steer the most
struts will stiffen out the chassis but do play a ssmalll affect on the over/under steer business
you don't want to add one suspension component and think it will act alone..all of them work together and if one is off then your handling can be off as well
Old Mar 16, 2004 | 11:16 PM
iam7head's Avatar
Default Re: (azian21485)
my fellow asian brother..
you just can't feel the difference with strut bar unless you're pulling some serious G's on the track.
Get a good set of sway bar and you'll be happy.
strut bar are pretty cheap to begin with, i would just go for those ebay stuffs.
for sway bar, get ST's
rear bar with oem front=more oversteer(perfect for fwd)
you could play around with tire size to get some more oversteer/understeer also.
Old Mar 17, 2004 | 07:24 PM
AccordCD5's Avatar
Hey, Thanks for all the info guys. I allready have the Suspension Tech. sway bars on my wish list
Dubs13
Suspension & Brakes
11
Jun 22, 2008 04:56 PM
ali7up
Oct 3, 2007 09:48 AM
WhiteRice02
Jul 16, 2006 01:20 PM
Brown-tec
Oct 30, 2005 06:51 PM
B_CRUZ!
22
Jun 26, 2002 03:25 PM
