JDM DC5 Cluster Odometer Swap?
Old Mar 16, 2004 | 09:07 PM
BlueIntegraBoy's Avatar
Default JDM DC5 Cluster Odometer Swap?
Ok, I have not been able to look inside of a USDM Cluster for an RSX, so I don't know the answer to my question. I want to put the JDM cluster in, but is there a way to just swap the odometer from my USDM cluster onto the JDM cluster? Like, does the odometer unscrew from the cluster?
Old Mar 17, 2004 | 07:28 AM
IcyDC5's Avatar
Default Re: JDM DC5 Cluster Odometer Swap? (BlueIntegraBoy)
I don't think you can take out just the odometer from the cluster. On the other hand, the mileage for the car is stored in the ECU, so there's no real need to swap odometers.
Hope this helps.
Old Mar 17, 2004 | 07:52 AM
Default Re: JDM DC5 Cluster Odometer Swap? (IcyDC5)
I always thought the mileage was stored on the cluster.
Old Mar 17, 2004 | 01:05 PM
IcyDC5's Avatar
Traditionally, it has been. But with the upgrade of the RSX/Civics the odometer is displayed digitally and the ECU keeps track of how many miles are on the car.
Old Mar 17, 2004 | 04:05 PM
So the JDM cluster will read miles on the odometer but KPH on the speedometer? Well, only one way to find out is stick my JDM cluster in.
Old Mar 17, 2004 | 09:14 PM
Jun DC5's Avatar
With the 2001 Civic, if you switch out odometers, the reading displays the mileage from the cluster. (IE: You have 20,000 miles, swap in a cluster from a car that has 3,000 miles, and in your cluster it will show 3,000 miles.)
Old Mar 17, 2004 | 09:50 PM
Default Re: (Jun DC5)
Thanks for clarifying things. I guess I can't swap the JDM cluster in and retain my mileage.
8bluddyknuklz
Jan 25, 2010 12:30 PM
Weak!EG
May 7, 2007 09:07 PM
lechuza05
May 2, 2006 05:26 PM
