CTR cams VS.
Old Mar 16, 2004 | 07:47 PM
speed_racer012's Avatar
Default CTR cams VS.
Just wonderning is it better to get skunk 2 stage ones with gears for 1000 or go CTR for 500+gears=750??? I plan on turboing but not for about 9 months or so. MAX. Or... are crane cams for turbos okay to run in my b16 without the turbo and go ahead and get those.
Old Mar 17, 2004 | 06:52 AM
Default Re: CTR cams VS. (speed_racer012)
Old Mar 17, 2004 | 07:01 AM
Davep's Avatar
If you just have a stock B16 you would be better off with ITR/CTR cams. You can get them for 300-400$ used.
Old Mar 17, 2004 | 07:32 AM
tim_adams85's Avatar
I'd recommend upgrading your valvetrain if you plan to get aftermarket cams. I've heard good things about the skunk2. Save your money and go with skunk2.
Old Mar 17, 2004 | 08:40 AM
sircrxracer's Avatar
If your going turbo spend the money on valvetrain don't worry about high lift cams. Rob
Old Mar 20, 2004 | 07:38 PM
SimbaDogg's Avatar
Default Re: (sircrxracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sircrxracer &raquo;</TD></TR><TR><TD CLASS="quote">If your going turbo spend the money on valvetrain don't worry about high lift cams. Rob</TD></TR></TABLE>
no...not even true, if you're going turbo, dont spend your money on the common NA high lift, LONG DURATION cams out there. crower makes some GREAT high light, short duration cams that work great on turbo. but really even when going NA dont spend the extra money on CTR cams. the benefits that you will get going w/ ctr as opposed to ITR are negligible (only the intake cam is different, and the duration is only a WEEEE bit longer not worth the extra $$$)
turbo...go with crower turbo cams, cheaper than skunk2 anyway.
Old Mar 21, 2004 | 05:06 PM
Default Re: (SimbaDogg)
how are the crower cams if I'm not turbo yet? I dont' wanna buy one set then turbo and have to buy another
Old Mar 21, 2004 | 05:37 PM
88 rex's Avatar
Default Re: (speed_racer012)
............And this is why this hobby is so expensive. If you want to do it right you have to spend the $$. You start skimping out on $$ and you won't acheive optimal performance.......Although I know what your saying about wanting a "universal" cam that will be fine in both instances. IMO, get the cam once you go turbo. Just leave it stock, or do other things, like suspension, until you are ready to seriously take on the task of increasing power.
Old Mar 22, 2004 | 05:49 AM
Default Re: (88 rex)
thats a really good point thanks
Old Mar 22, 2004 | 06:56 AM
phan's Avatar
itr/ctr cams in b-vtec turbo setups own you all. there was a thread here on h-t (i'll look for the link) where a guy made 615whp-ish on a b-vtec (gsr?) turbo with itr cams.
Old Mar 22, 2004 | 10:55 AM
phan's Avatar
Default Re: (phan)
i found the link...
https://honda-tech.com/zerothread?id=704660
Old Mar 22, 2004 | 10:56 AM
^jefs0ng's Avatar
Banned
I was gonna get these cams too
Old Mar 22, 2004 | 10:57 AM
phan's Avatar
Default Re: (^jefs0ng)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ^jefs0ng &raquo;</TD></TR><TR><TD CLASS="quote">I was gonna get these cams too </TD></TR></TABLE>
i had some ctr cams awhile back, but i sold them because i'm going turbo...ARGH!
gsr x civic
Sep 29, 2006 01:47 PM
CaliforniaHighwayPatrol
21
Sep 6, 2005 07:51 AM
blakacintegera
Jul 21, 2003 12:52 AM
STEALTHMODECOUPE
Jun 23, 2002 07:05 PM
far
Apr 4, 2002 09:52 AM
