difference between usdm's b16 vs b18 in crx
Old Mar 16, 2004 | 04:18 PM
newBcrxer's Avatar
Default difference between usdm's b16 vs b18 in crx
ok guys. decision time!. either the b16(the 00' vtec motor, not sure whats its called) or the b18c1(gsr motor right?) . i dont know which one to put in because i dont know which one would be better suited for the car, its a 90' crx si. i heard that the b16 can redline more or rev higher then the b18.whats the diff in a crx? but what i'm looking for is to have low end power but also on freeway be able to run too. let me know what you guys have n' if you like it. right on guys!
Old Mar 16, 2004 | 04:22 PM
jedubz's Avatar
Default Re: difference between usdm's b16 vs b18 in crx (newBcrxer)
First off right now I'm questioning your actual knowledge. The b16a has a near perfect rod-stroke ratio, (1.74, 1.75 is theoretically perfect) so therefore it can Rev higher in the end. In sheer numbers though you're looking at quite a big advantage going with a GSR motor. And a GSR can rev pretty high also. If you want low end, you want a turbo motor or an LS(or B20)/VTEC But I really suggest you do some research before making such a major decision becasue right now you seem like you're in the dark.
Old Mar 16, 2004 | 04:28 PM
newBcrxer's Avatar
Default Re: difference between usdm's b16 vs b18 in crx (jedubz)
yeah .. i'm pretty confused .. in the dark with my little night light. maybe like what would be the diff in 1/4 mile on the motor for a crxer. but dont know whats better to have. what would you guys recommend? i can get a hold of either motor thats why
Old Mar 16, 2004 | 05:11 PM
xxmaxhardcorexx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newBcrxer &raquo;</TD></TR><TR><TD CLASS="quote">yeah .. i'm pretty confused .. in the dark with my little night light. maybe like what would be the diff in 1/4 mile on the motor for a crxer. but dont know whats better to have. what would you guys recommend? i can get a hold of either motor thats why </TD></TR></TABLE>
well price is an issue? here is my rundown.
you get a b16 and have some fun after a while
you want to go faster. so then you spend the money to build it
and you loose the reliabilty of the motor. i have seen crx's w/ mini me's tear up b16's or be dead even w/ little boltons. b16+crx give and take 14.5 and up in the Q- mile.
i say do it right the first time go with a R-motor the motor is built from honda
and ready to go, and you have the honda reliablity, this swap will be great
for all around, track and not to mention your car would be a beast in the street
and most likely a very low 13 second car.
Old Mar 16, 2004 | 10:31 PM
91Tege's Avatar
i say do it right the first time go with GSR motor. GSR motor would be a good swap and it be ready to go. Your car would be a beast in the street.
But do u just want to do the swap or do the swap and do some work to it
Yo hit me back
H22SHtec
Jan 10, 2011 05:17 AM
hellajdm333
32
Apr 4, 2010 04:22 PM
Hatch_Boy
May 21, 2009 07:08 PM
bhigh
Feb 3, 2009 04:08 PM
crxGLASSTOPcrx
10
Nov 7, 2001 09:27 PM
