what kind of engine do i got?
I read on pure honda forums that my 97 del sol si has a b16y8, i keep reading that my car is dohc, but i have also read that it is sohc. Please let me know!
post a pic, or look for the engine code on the front of the block, where the tranny meets the block, underneath the front left side of the valve cover....
either it's a d16y8 that's been swapped in or its a b16a3?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NateTL17 »</TD></TR><TR><TD CLASS="quote">I'm pretty sure you mean D16Y8, an SOHC D-Series engine. The Del Sol Vtec has the B16(what you are thinking of, 160hp), which is a DOHC motor.</TD></TR></TABLE>
del sol si from 92-95 had d16z6 and 96-97 had d16y8 both SOHC vtec.
the only dohc vtec del sol was the del sol dohc vtec
which had a b16
which had a b16
an easier way to tell... if he obviously doesnt reconize a differnce in a DOHC and SOHC valve cover... where is the red line... 6500 or 6800 would be sohc non vtec, 7k would be sohc vtec, and 8kish would be dohc vtec
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicrida3 »</TD></TR><TR><TD CLASS="quote">all 96-00 civics came with y8's
Thats funny cause looking outside at my 99 Civic with factory motor which is not a y8.
pop the hood and if all the spark plugs are in the middle of the valve cover and in a little indented trough type thing you have the b series if they are to the front or to the back and aren't in a little trough type thing then you have the d series
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lohatch »</TD></TR><TR><TD CLASS="quote">all 96-00 civics came with y8's.................................
d16y7
WTF are you talking about? Only the EX came with a Y8. The HX came with a Y5 and everything else came with the Y7.
d16y7
</TD></TR></TABLE>WTF are you talking about? Only the EX came with a Y8. The HX came with a Y5 and everything else came with the Y7.
k1honda
Apr 9, 2014 07:46 PM
Red_Si
Nov 25, 2002 11:39 AM
