Oil Filter, am I missing a gasket?
where the oil filter is located im having a dripping leak, Im under my car looking around for what the problem is...
Am I missing a O-ring gasket around the filter? (where my finger is)
check around where you took it off, sometimes they get stuck on the cylinder when its removed, or you might have one from an old filter stuck on there, but that would cause a much bigger leak
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade »</TD></TR><TR><TD CLASS="quote">No, your not missing a gasket.
Have you made sure that old oil ring gaskets have not stuck to the engine block?</TD></TR></TABLE>
Yeah done that one once...oil everywhere.
Have you changed your drain plug gasket? That could the the culprit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi »</TD></TR><TR><TD CLASS="quote">No you're not missing it. The red ring is the o-ring.
Maybe another o-ring is stuck on the oil filter housing. Check that.</TD></TR></TABLE>
no, but the oil filer adaptor is leaking!!!! (where the block is conencted to it)
I need a gasket or a o-ring seal for it
No your not missing a gasket on that filter but also make sure that you didn't Double Gasket (Leaving the old one on) You should also make sure when you put the new one on pretty tight so you dont have any leaks and clean up any excess oil that may be dripping so that way it doesn't look like your leaking any new oil.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 976 »</TD></TR><TR><TD CLASS="quote">Fram, that's your problem.
Go get an OEM Honda or Hamp! </TD></TR></TABLE>
Many OEM Honda filters are made by Fram.
READ THE HONDA OEM filter next time smart ***!!!
IT SAYS FRAM ON IT......boooya......
don't hate that which you don't know!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">READ THE HONDA OEM filter next time smart ***!!!
don't hate that which you don't know!!</TD></TR></TABLE>
not all honda filters say FRAM on it. when i dont have time to get a honda filter, i use the same double guard fram in the pic. atleast it does have the anti-flowback valve. anyways, ive never had a problem with them. just make sure the surface of the block is clean (wipe it w/ rag or paper towel) and use ur finger and dab oil onto the rubber gasket on the filter. hand tighten + 1/2 turn (i usually hand tighten + 1 full turn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BatuKing »</TD></TR><TR><TD CLASS="quote">if you tightened it too much it can create a small tear and leak.
BTW do you have an oil cooler attached ? if so check the gasket for that</TD></TR></TABLE>
its the oil cooler thats leaking i bet
i gotta remove it, but i dont have a deep socket 21mm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MilanoHatch98 »</TD></TR><TR><TD CLASS="quote">try a honda filter. A lot of the aftermarket filters i see leaks, NOT ALL, but a lot. And I am a Lube tech at a Honda dealership so i see A LOT.</TD></TR></TABLE>
hehe i double gasketed a customers car the other day at work. its a bad feeling
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic »</TD></TR><TR><TD CLASS="quote">
i use the same double guard fram in the pic. atleast it does have the anti-flowback valve.</TD></TR></TABLE>
all aftermarket oil filters that are supposed to be used on hondas should all have an anti-drainback valve. that rubber looking piece under those holes where the oil leaves the filter is an anti-drain back valve. some valves are better than others. there are two types, rubber and silicon. generally a silicon ADBV is better than a rubber one. you can tell the difference between the two b/c a silicon ADBV is red or orange in color and a rubber ADBV is black.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BADEG6 »</TD></TR><TR><TD CLASS="quote">
hehe i double gasketed a customers car the other day at work. its a bad feeling</TD></TR></TABLE>
i've done that exactly twice,
start it up, and i'm like wtf? this was one of the first times i did an oil change, about 3-4 years ago.
second time was on my sister's escape, started it up, oil everywhere, knew right away what it was.
both times there was an extra gasket stuck on the block, leaked really fast.
check to see if you got an extra gasket on there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi »</TD></TR><TR><TD CLASS="quote">So the basic Fram orange filters suck?</TD></TR></TABLE>
i would have to say yes. based on their construction, they are one of the most cheaply made oil filters.
Booooya?
Have you ever seen 'fram' on Hamp, no.
Booooya?
