Plenty of easy questions...need answers please!
I have compiled several questions that might seem petty to some, but I really need to know. See sig for my setup. Thanks in advance.
What intake do I need to use for a da6a6 with a b18b TB and still have proper fitment at the TB and the lenght of the piping?(waiting on the y8 IM)
I am using a 13/15 master cylinder on my hatch with the rear disc conversion from a CRX Si. Any performance pro's to go to a larger( 7 / 8 ) master cylinder?
Are the Russell SSbrake lines DOT approved?
Any one using side exit exhaust? I plan on building a new custom exhaust system exiting the passenger side before the tire. Any info?
Differences between the z6/y8 aftermarket header on the a6 block, compared to the a6 aftermarket header?
Can I put the A6 complete head on my stock 90 dx block? Any info?
What manufacturer to upgrade fuel pump?
Can I put the b18btb/y8 im on the d15 and wire up MPFI? I believe I have everything I need for the MPFI swap...what exactly is needed for this?
Pricing on balancing stock injectors?who/where to go?
Anyone using Zdyne SECU for all motor? comments/info?
Complete carb conversion kits available for a6 yet? info? price?
Good place to buy the ES motor mount inserts for cheap?
I know these are stupid questions, but I ast least got them all in on one huge post. thanks again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by busychild »</TD></TR><TR><TD CLASS="quote">
Of course there is a performance gain by upgrading to a larger MC, also the 91 EX 4door is a 15/15th MC.
I don't believe they are DOT approved (I could be wrong), but you'll be fine using them or Earl's lines.
No info, but why? I think it would look like *** and you would dent the **** out of it.
Walbro.
Need injectors and resistor box as well as ECU I believe.
RC does this also check your phonebook there should be a few places local to you that offer this service as well.
Summitracing.com or jegs.com
Walbro.
...and I thanks him for that. At least I asked them all in one post....
RC engineering gave the price of 24.95/injector plus the return shipping and handling.
I also got PM'd that inlinefour.com also carries the motor mounts for cheap.
I doubt this car will ever see the daily drive; it is being built specifically to be tracked, but not trailered.
I could not find a direct part for Walbro. I will search more.
Thanks for the help!
BLUE EH3
13
Aug 20, 2006 12:18 PM
