Can a 5th gen use a s2000 oil filter?
Old Mar 16, 2004 | 12:20 PM
SOHCMAN's Avatar
Default Can a 5th gen use a s2000 oil filter?
I thought I remember hearing this, so I picked one up while I was getting other parts. It says it was made in canada (is this the good type??) the part number I got was 15400-pt7-005. it dwarfs the new tiny filter that honda is going to (this is the old type obviously)
anything I should look out for? thanks...
sohc
Old Mar 16, 2004 | 12:26 PM
jwogen1's Avatar
Default Re: Can a 5th gen use a s2000 oil filter? (SOHCMAN)
i would be surprised if the filters are interchangeable, did you check part numbers for both or where they the same?
Old Mar 16, 2004 | 12:37 PM
fw190bvi's Avatar
Default Re: Can a 5th gen use a s2000 oil filter? (jwogen1)
i remember a few threads on this a while ago.....i believe it will work, but im not sure......BTW, they are both F series engines
Old Mar 16, 2004 | 01:36 PM
Beach Accord's Avatar
Default Re: Can a 5th gen use a s2000 oil filter? (fw190bvi)
yes you can use the s2000 filter on your accord.
thats all i use
BTW the REAL s2000 oil filter should say Made in Japan and the companys name "Toyo Roki" should be printed on it too.
15400-pcx-000????
i dont have one nearby
Old Mar 16, 2004 | 02:02 PM
jwogen1's Avatar
interesting--learn something new everyday
Old Mar 16, 2004 | 02:03 PM
fw190bvi's Avatar
yea...apparently theryre prefered because they allow the oil to flow at a higher rate??.....something along that line
Old Mar 16, 2004 | 02:07 PM
SOHCMAN's Avatar
so, I got the (fram?) made one from canada them...hmmmm. crap! its good to know I can use it at least.
sohc
Old Mar 16, 2004 | 02:35 PM
pimpinhonda's Avatar
all honda's take the same oil filter except for the passport. there are 2 kinds that you can use sand the only visable difference is the size
Old Mar 16, 2004 | 05:16 PM
Default Re: Can a 5th gen use a s2000 oil filter? (pimpinhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pimpinhonda &raquo;</TD></TR><TR><TD CLASS="quote">all honda's take the same oil filter except for the passport. there are 2 kinds that you can use sand the only visable difference is the size</TD></TR></TABLE>
i believe the insight might use a different filter as well......
the frams really suck ***
the filtechs were decent
but i would stick with the japanese toyo rokis
Old Mar 16, 2004 | 05:21 PM
Conechaser's Avatar
I'm 99% sure you can use an '88 Montero Oil Filter, it is HUGE and screws right on and the seal lines up.
Old Mar 16, 2004 | 05:22 PM
Conechaser's Avatar
Default Re: (Conechaser)
nm, i just asked my friend who used it, he said it leaked a little bit.
Old Mar 16, 2004 | 07:29 PM
accordhybrid's Avatar
I use the S2K filters on my mom's accord, my H22 and my girls prelude it fits, and also for ***** and giggles I tried it on my dads 92 CX and it fit also.
Accordhybrid
Old Mar 17, 2004 | 08:46 AM
teamlegacy's Avatar
Default Re: (accordhybrid)
any worth it differences?
Old Mar 17, 2004 | 09:14 AM
H22CB7's Avatar
Is their any real purpose for switching to the s2000 or is a JDM thing?
Old Mar 17, 2004 | 10:21 AM
only reason i use them is cause they are made in japan by toyo roki, which is a quality manufacturer.
cant say the same for fram or even filtech
unbreakable_35
Dec 31, 2008 03:16 PM
coot_er
May 28, 2008 04:46 PM
rohec04
Aug 7, 2007 10:11 AM
020
Jan 31, 2004 09:37 AM
