Reset Ecu for Aem CAI
Old Oct 19, 2001 | 02:34 PM
94autotegLS's Avatar
New User
Default Reset Ecu for Aem CAI
ok just got an CAI, i heard about resetting the ecu by taking off the neg charge cable off the battery what exactly does this do does it really matter do u gain performance by doing this, or better gas milaege can u lose any performance thanx for your help
Old Oct 19, 2001 | 03:47 PM
Leimokei's Avatar
New User
Default Re: Reset Ecu for Aem CAI (94autotegLS)
it just resets ur ecu...so your car now knows it has a performance part...
disconnect battery....for 15 mins...then turn on your car let it idle for 3 min turn it off and then turn it on again
Old Oct 19, 2001 | 03:58 PM
New User
Default Re: Reset Ecu for Aem CAI (Leimokei)
i guess i mean what exactly happens when u do this yeah the car understands you have a performance part but what in turn does it do
Old Oct 19, 2001 | 04:13 PM
Phat Corolla's Avatar
New User
It will adjust to the new variables its sensors are giving. A good example is the CAI thing...It will sense that air is coming in at a greater rate and is colder, and It will adjust your fuel supply and some other things accordingly, therefore making the engine perform better. I'm sure someone else here has a better explaination.
Old Oct 19, 2001 | 04:40 PM
New User
Default Re: Reset Ecu for Aem CAI (Phat GS-R)
thanx man any more explanations just was wondering if i'd lose gas mileage and things like that
Old Oct 19, 2001 | 04:50 PM
Muckman's Avatar
Moderator in Chief
u dont need to do all that jazz to reset your ECU.. you can reset it with the push of a button on the 3rd gen integras! reach under your steering wheel with your right hand.. run your hand towards the center along the lip of the dash under the steerting wheel. You will find a little square button that will reset the ECU.
I think the ignition has to be at least on, or to accesory. I reset it when the engine is running to.. doesnt seem to disturb anything. Push and hold it for a few secs. your CEL will come on then go off.
[Modified by Muckman, 8:51 PM 10/19/2001]
Old Oct 19, 2001 | 05:24 PM
New User
Default Re: Reset Ecu for Aem CAI (Muckman)
Are you sure that hitting that button fully resets the ECU??? I have never heard that. I know it resets the maintenance required light, but you're saying that it fully resets it...that would be cool if it was the case though.
To answer the gas mileage question...you shouldn't lose gas mileage, in fact you may gain a mile or two per gallon. The reason is that since the air is colder, it combusts more powerfully therefore needing less gas to make the same amount of power.
Old Oct 19, 2001 | 05:30 PM
immortal's Avatar
Banned
uh no you are COMPLETLEY Wrong. thats to reset the maintenance required light that comes on annually telling you to change your oil. that has nothing to do with your ecu.
disconnecting the negative battery terminal or removing two of the fuses (back-up and someo ther one, the two top left ones i believe) will reset your ecu.
Old Oct 19, 2001 | 06:19 PM
Tanner's Avatar
New User
Default Re: Reset Ecu for Aem CAI (immortal)
Yeah immortal is right that only resets the Maintenance light NOT the ECU...
Old Oct 19, 2001 | 06:21 PM
ITR 2K's Avatar
Why don't you just remove the ecu fuse?!?!?!. It's the same thing, and you won't have to set everything in your car again, like your radio, and clock, etc.
[Modified by ITR 2K, 3:21 AM 10/20/2001]
Old Oct 19, 2001 | 11:26 PM
New User
Default Re: Reset Ecu for Aem CAI (GS-Racer01)
Okay, good. That's what i thought, but i figured maybe there was something i didn't know...
Old Oct 20, 2001 | 09:49 AM
Calavera's Avatar
Pulling out the fuses on the fuse box below the right side of the steering wheel will reset it, I heard.
But you don't really need to reset it immediately because after 1 day or so the ECU just automatically adjusts to the new aftermarket part.
I read that in this forum somehwere.
Old Oct 20, 2001 | 11:20 AM
ITR 2K's Avatar
Default Re: Reset Ecu for Aem CAI (Calavera)
Why wait one day, when it'll only take 1 minute to remove the ecu fuse. That way you won't have to drive around with a crazy idle.
[Modified by ITR 2K, 8:20 PM 10/20/2001]
ExVtec
May 9, 2009 08:57 PM
integramic
Oct 14, 2008 09:22 AM
A-busive
Aug 8, 2005 11:01 AM
EdLeake
21
May 30, 2004 06:24 AM
macdaddy
Apr 15, 2002 03:01 PM
