another civic idle problem
Old Mar 16, 2004 | 10:19 AM
1hotcivicSi's Avatar
Default another civic idle problem
my idle is really gay sumtime when i pull up to a light it will be at 15-1600 rpms other times its at 1000 other times its at 200-300 its just soo weird most of the time its really low ..... i had my timing retarted should i put it back to stock
i had it retarted for nitrous but now the nitrous is out should i put the timing back wil that help my idle???
Old Mar 16, 2004 | 01:52 PM
Default Re: another civic idle problem (1hotcivicSi)
Old Mar 16, 2004 | 02:01 PM
2lua's Avatar
set the base timing on your car, check for vacuum leaks. if still having the same problem then clean your iac, then fitv.
PremiumPrelude
Mar 23, 2008 03:45 PM
NoVALude
Nov 20, 2006 11:02 AM
stoopid_monkey
Apr 26, 2005 11:22 PM
rtiadnoh
Feb 24, 2004 04:44 PM
REDBARON
Oct 4, 2001 07:40 PM
