removal or rear wheel stud
Old Mar 16, 2004 | 08:18 AM
Lo-Buck EF's Avatar
Default removal of rear wheel stud
*removal OF rear wheel stud**
on a rear drum equiped car, can the rear wheelstuds be removed w/o taking the trailing arm off the car and appart?
search yealded no info and its snowing (again) so i cant go look.
-spenc
Modified by Lo-Buck EF at 12:29 PM 3/16/2004
Old Mar 16, 2004 | 08:32 AM
red civic standard's Avatar
Default Re: removal of rear wheel stud (Lo-Buck EF)
yes they can. you will need to remove the brake assembly that is inside the drum to make room to get it out but you don't have to remove the trailing arm.
Old Mar 16, 2004 | 08:39 AM
Lo-Buck EF's Avatar
Default Re: removal of rear wheel stud (red civic standard)
thanx
Old Mar 16, 2004 | 09:39 AM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
http://www.fourthgenhatch.com/wheelstud.html
Old Mar 16, 2004 | 10:50 AM
Lo-Buck EF's Avatar
that link is for front. i need info for rear.
-spenc
shortlid
Sep 26, 2007 09:33 AM
CivicVX94
Suspension & Brakes
Feb 5, 2007 01:41 PM
BlueShadow
10
Oct 27, 2004 12:08 PM
Soulless
Nov 17, 2003 12:26 AM
Civic44
May 16, 2002 09:04 PM
