H22A Parts, JDM Headlights, EL Gauge Cluster, Prelude Parts
1996 Honda Prelude EL Gauge Cluster, comes with inverter box and it comes with the dash harness out of a 1996 Honda Prelude VTEC. This swap is 100% plug and play into any 92+ Prelude!! - $300 shipped
Complete JDM H22A Head. Comes with all sensors, cams, valves, springs retainers, VTEC selnoid, distributor, valve cover, intake manifold, fuel rail, EGR, throttle body. Everything needed to make your H23A1 a 2.3L DOHC VTEC engine! -SOLD
Clutchnet 6 puck clutch, heavy duty pressure plate, throw out bearing and clutch masters 8lb flywheel for any H or F series - SOLD
H22A Oil Pan - $60 shipped (comes with bolts, pick-up, windage tray and new gaskets)
H22A Crankshaft - SOLD
H22A Pistons - SOLD
H22A Oil Squirter Assembly (will work in H23A1 block with some modification) - $50 shipped
Unorthodox Red Alternator Pulley - SOLD
Unorthodox Red Crank Pulley - SOLD
H22A PS Pump - $60 shipped
H22A Alternator - SOLD
PS Bracket - $30 shipped
Alt Bracket - $30 Shipped
AC Bracket - $30 shipped
H22A Thermostat Housing - $40 shipped
H22A Water Pump - $40 shipped
H22A Oil Pump - $40 shipped
JDM 1 Piece Headlights - $300 shipped
JDM EL Gauge Cluster - $100 shipped
JDM Non-EL CLuster - $50 shipped (plug and play into USDM car)
Gas, Water Temp, Warning Lights - $50 shipped
H22a Axles - SOLD
Prelude knuckles, hubs (have Skunk2 wheel studs and lug nuts), Bremo front rotors 11.1" slotted/drilled, and power slot rear rotors, calipers, twin piston Acura Legend GS calipers up front, stainless Russel brake lines. All parts were purchased brand new, I have ALL recipts - $850 Shipped (4x114.3)
H&R Stage 3 Race Springs 92+ Prelude w/struts - $150 shipped
MSD SCI-L, MSD Blaster 3 Coil, MSD Plug Wires, MSD Coil Bracket - SOLD
92-96 Prelude OE Fog Lights, harness, custom made carbon fiber covers - $200 shipped
Tranny from H22A - $650 (pick-up)
USDM H22A1 Complete Longblock - SOLD
Carbon Fiber Hood - $80 (92-96 prelude, needs to be wet sanded/buffed)
I also have misc. interior pieces from 92-96 Prelude! Pick-up is avaliable on any/all parts! I'll add pictures soon!
-Mike
Pictures:
Modified by JDM BB2 at 4:58 PM 3/17/2004
Modified by JDM BB2 at 5:19 PM 4/6/2004
H22A Pistons - SOLD
H22a Axles - SOLD
-Mike
Pictures:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projekakkord »</TD></TR><TR><TD CLASS="quote">Would u sell the pulleys for P/S and Alt together, and also. If your prelude was an auto, do you have the ATU?</TD></TR></TABLE>
Prelude is 5speed, you want the alt pulley and ps pulley ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_CB7 »</TD></TR><TR><TD CLASS="quote">Interested in the oil pan. Any pics of it.
If its in good condition i'll take it also, how much for all the pulleys?
I'll snap some pictures of the oil pan tomorrow. Which pullies do you want? I have the AEM alt pulley, unorthodox crankshaft pulley and the unorthodox alt pulley and all of the stock pullies. (might work on PS pump, not sure).
-Mike
</TD></TR></TABLE>I'll snap some pictures of the oil pan tomorrow. Which pullies do you want? I have the AEM alt pulley, unorthodox crankshaft pulley and the unorthodox alt pulley and all of the stock pullies. (might work on PS pump, not sure).
-Mike
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kin6david »</TD></TR><TR><TD CLASS="quote">you wouldnt be able to sell me the tranny for 600 shipped would you...?</TD></TR></TABLE>
You've been IMed
You've been IMed
