FS: 1989 Civic HB - B20 VTEC - $3700 obo - Georgia - Atlanta Area
89' Civic Hatchback
Ignore the smoke(I got NEW!!! Valve stem Seals)
Car in Motion!!! (Right-click & Save As...)
Performance:
B16a head
JDM B20B Block (ITR Water pump, Oil pump & Timing Belt)
GS-R Cams & JG Gears
3 in. Ram Air Intake
Skunk2 Intake Manifold
9.2mm Spark Plug Wires
MSD Blaster Coil
MSD 6AL
MSD Manual Dual Stage Rev Limiter
JDM 4-1 Headers
B16 Tranny w/LSD
ITR Flywheel
ITR Clutch
CTR Pulley
APEXi World Sport CatBack Exhaust
AZ Racing Motor Mount Kit
Del Sol Dual Core Radiator
AZ Racing Shift Linkage
Skunk2 ECU
Type R Valve Cover
B&M Short Shifter
VTEC Parts(Done Right)
Golden Eagle Oil Filter VTEC adapter
All Earl's Fittings
Golden Eagle Dowel pins
Machine tapped 1/8 aluminum plug
Suspension:
KYB AGX Struts and Coil Over System
Place Racing Front Crossmember
93 LS Rear Disc Brakes, E-Brake & Prop Valve.
Exterior:
1989 Civic Si OEM Front Lip
15' 00' Civic SI Rims
20% Black Tinted Windows
JDM Amber Corners
Interior:
5' Autometer Monster Tach
Autometer Air/Fuel Ratio Gauge
Autometer Oil Pressure Gauge
CRX SI Gauge Cluster
Aluminum Gauge Bezel
Type R Shift ****
AIM: Rdoggins
Email: R.doggins@mchsi.com
Here is what it would cost to do it again...
Civic $550.00
Good Billet Mounts $250.00
B20 / B16a Head $1,200.00
S1 tranny & LSD $600.00
Apexi WS exhaust $450.00
x member $200.00
radiator & fan $150.00
JDM 4-1 Header $400.00
Skunk2 Manifold $250.00
Coilovers $125.00
AGX Struts $350.00
MSD $350.00
Total $4,875.00
So who wants to save $2,000. This is given you do ALL the work.
Modified by crxman00 at 1:53 PM 3/25/2004
Performance:
B16a head
MSD Blaster Coil
MSD 6AL
JDM 4-1 Headers
B16 Tranny w/LSD
ITR Flywheel
ITR Clutch
CTR Pulley
Skunk2 ECU
Type R Valve Cover
B&M Short Shifter
All Earl's Fittings
Suspension:
Exterior:
JDM Amber Corners
Interior:
Type R Shift ****
AIM: Rdoggins
Civic $550.00
x member $200.00
Coilovers $125.00
AGX Struts $350.00
MSD $350.00
Total $4,875.00
TurBoTeG
May 18, 2007 07:10 PM
dajman94
Mar 16, 2006 10:54 PM
