JDM 15" Weds what do you guys think?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AJ PwR »</TD></TR><TR><TD CLASS="quote">The wheels look good but defnitely too small for the car.
agreed
agreed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">The wheels look good but defnitely too small for the car.</TD></TR></TABLE>
They are the right size for the car rice boy ...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gr8GrZ »</TD></TR><TR><TD CLASS="quote">15" are for racers. function over fashion! great for togue and racing. 16" is more jdm comestic fashion, then true jdm function. </TD></TR></TABLE>
really? who said ...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kwik2nec »</TD></TR><TR><TD CLASS="quote">
Its common physics....
</TD></TR></TABLE>Its common physics....
I'd say go for it. The bigger the rims, the more rotational mass you'll have. Hurting acceleration a bit but the good thing about having bigger rims is that it'll handle a bit better.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VBP_03Si »</TD></TR><TR><TD CLASS="quote">I'd say go for it. The bigger the rims, the more rotational mass you'll have. Hurting acceleration a bit but the good thing about having bigger rims is that it'll handle a bit better.</TD></TR></TABLE>
You will not handle better .....bigger is not always better ....
https://honda-tech.com/zerothread?id=799725
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hooligan317 »</TD></TR><TR><TD CLASS="quote">at first i said they were too small, if you really are gonna race then it's fine, if it's a street only ride... go 16 IMO</TD></TR></TABLE>
I would 16's are a good size for the street ...
Not to big ....and enough tire so you wont have to worry about every single pot hole ...
it would if the rims were 15x6.5 compared to 16x7, but when its 15x7, it has the width, smaller rotational mass, and plus 15 is as small as you can get with a big brake upgrade.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCIVIC »</TD></TR><TR><TD CLASS="quote">Id say they look fine as long as you slam it correctly</TD></TR></TABLE>
slam =
slam =
Ultimate JDM master Gr8GrZ said that because it is THE JDM thing to do. JDM Gr8GrZ says that if you put 15" wheels on your EP, it is the TRUE JDM FUNCTION. So all your JDM ****** out there, listen to this JDM master and put on these JDM wheels that have the JDM function. JDM POWA.
But honestly, I think those weds would look pretty cool on a white EP. They just have to be a little lower than the normal lowered EPs, but not necessarily "slammed."
</TD></TR></TABLE>Ultimate JDM master Gr8GrZ said that because it is THE JDM thing to do. JDM Gr8GrZ says that if you put 15" wheels on your EP, it is the TRUE JDM FUNCTION. So all your JDM ****** out there, listen to this JDM master and put on these JDM wheels that have the JDM function. JDM POWA.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ep3minivan »</TD></TR><TR><TD CLASS="quote">
But honestly, I think those weds would look pretty cool on a white EP. They just have to be a little lower than the normal lowered EPs, but not necessarily "slammed."</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by celtic »</TD></TR><TR><TD CLASS="quote">BIGGER RIMS DO HANDLE BETTER ON ROAD RACING. its true....
Prove it ....
</TD></TR></TABLE>Prove it ....
its "form follows function"....
15" wheels are lighter, less rotational weight,....but less tire width unless you get a 15by 7.5's those would be pretty darn sticky....but small wheels/tire sizes hurt your top end acceleration...thus they are good for "out of the hole" driving, as in backroads, small tight tracks/courses etc....
I agree with anything 17" or up on an FWD import compact car.....its just for show...thats why i got rid of my 17" motegis as seen in my imagestation below...
I now run 15" BBS meshes....i could tell a HUGE difference in holeshot acceleration, and cornering ability, the steering feels ALOT lighter and more flexible than when i had the 17's
I am staying with 15's and 16's.....by the way, my next wheels are going to be the ROTA GT3 wheels in red...they are GAB look alikes heeheheheh
they are 16*7's and only 159 a piece from modacar!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gr8GrZ »</TD></TR><TR><TD CLASS="quote">What do you guys think of 15" Weds Sport TC005 White with Blue Weds Decal look on a ep3?
It would be easier to say if you had pics.
