ITB's and stock compression ratio
Old Mar 15, 2004 | 08:30 PM
WarrenB's Avatar
Default ITB's and stock compression ratio
I am considering buying a set of A-Sport Japan 43mm ITB's for my R. Compression Ratio has been brought up and I have been told that to make it worthwhile for the ITB's, I should have at least 12:1 compression. It has been recommended to me that I get a set of CTR pistons and of course a new head gasket such as the Spoon one to acheive this CR. My thoughts on this matter are: if I am going to rebuild the bottom end, would I even bother going with CTR pistons, and maybe get a 2.0L stroker kit and build it up right...
What are your thoughts on ITB's with stock compression???
Old Mar 15, 2004 | 08:40 PM
WarrenB's Avatar
Default Re: ITB's and stock compression ratio (WarrenB)
Oh yeah, the deal I would be getting on the ITB's themselves seems pretty sweet, but starting to think of what else potentially should be done if I were to decide to do any bottom end stuff, god it makes me feel broke. Of course, I would just have to do the clutch, flywheel, probably change the final drive, uprgrade LSD, and all that stuff, if I would do it, I would have to do it up right... Suddenly we are into money where I could practically order up a 2L Spoon engine and just sell mine. hehe.
Old Mar 15, 2004 | 08:41 PM
Bbasso's Avatar
ITBs...
What ECU setup are you going to use with them?
Old Mar 15, 2004 | 08:43 PM
Kendall's Avatar
I was actually about two steps from running ITB's on my stock engine. I had a set of GSXR 1000 ones that were completely set up for it, and should have done the job reasonably well (but I sold them). Naturally, they will perform better with the increased compression ratio, but I don't forsee there being any hindrances to running a set with stock compression.
Old Mar 15, 2004 | 08:53 PM
WarrenB's Avatar
Default Re: (Kendall)
ECU: Hondata S200. Valvetrain: TODA SPec B's w/Toda retainers, Jun valves, springs, and cam gears.
Old Mar 15, 2004 | 09:26 PM
Chris N's Avatar
Default Re: (WarrenB)
Toda B's are a waste on stock compression to begin with.
And ITBs? I don't get why they are good for cars that aren't highly modified.
ITBs were always the 'last step' after you had a very highly built, tuned engine.
hatch22ajdm
Engine Machining & Assembly
Jun 1, 2018 03:33 AM
EG type GTR
Aug 6, 2006 11:59 PM
civic-si-2000
May 2, 2005 01:25 PM
emotionisdead
Apr 6, 2004 07:59 PM
