motor probs please help!!!
Old Mar 15, 2004 | 06:51 PM
KiNG $h!t's Avatar
Default motor probs please help!!!
ok i have a ls motor b18b to be exact. Sometimes when i get on it and shift to second about mid second i will feel the motor start to studder what could it be???
also i get a iradic idle(@ idle it will jump fomr 1k up to 1500 then back down) what could be the reason for that?? thanx for ur help
Old Mar 16, 2004 | 10:49 AM
KiNG $h!t's Avatar
up
Old Mar 16, 2004 | 04:14 PM
KiNG $h!t's Avatar
bump
Old Mar 16, 2004 | 04:19 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: motor probs please help!!! (this guy 2fast)
make sure the ground on the thermostat housing is tight.
2lua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by this guy 2fast &raquo;</TD></TR><TR><TD CLASS="quote">ok i have a ls motor b18b to be exact. Sometimes when i get on it and shift to second about mid second i will feel the motor start to studder what could it be???
also i get a iradic idle(@ idle it will jump fomr 1k up to 1500 then back down) what could be the reason for that?? thanx for ur help</TD></TR></TABLE>
it could be quite a few difference problems though like bad grounds, misfire, low fuel pressure, bad injector... about the irattic idles again it could be bad ground dirty iac, advanved timing, vacuum leaks...
Old Mar 16, 2004 | 05:26 PM
KiNG $h!t's Avatar
well im gunna check out the thermostat prob because mine doesnt work
Sold Out
Jul 14, 2008 09:59 AM
racer_X_123
Oct 19, 2005 01:00 PM
draggpa
Aug 5, 2005 03:56 AM
screech
Jun 2, 2004 01:53 PM
t5er
Dec 15, 2002 07:25 AM
